First post, by DoomWarrior
hi
i want to install Pinball 3D/VCR but the installer claim there is not enough disk space. First i thought it could be the wrong size of my diskdrive (programm overflow after 2GB or so)
so i set this to 100MB. But without success.
So i recompile with debug stuff and start debugging (my asm-skills aren't the best)
after poking around a little bit it got THE funny thing
INT 21 (AH 1C)
the return value seems to be ok, the programm now checks
against 00F8 but the value is F8F8
i found some note in the internet
check_FAT: Unusual media descriptor (0xf0!=0xF8)
so the game find out it isn't a valid drive, if i understand the code correct, and skip C:\ (my drive)
so i Set register to 00F8 and now the installer work...
is this a 'bug' or did i miss some configuration ?
Bye
Reply 1 of 16, by DoomWarrior
so i would like to look after this issue, but i need a starting point, where is the Dos Interrupt handling stuff, i couldn't find anything yet 😖
i added some code for debugging. I was wondering why it isn't possible to set AH for example. So i added that stuff. imho it's quiet usefull. 😀
    debug.cpp.DIFF
    1.46 KiB
    298 downloads
    8bit register manipulation (AH,AL...DL)
Reply 3 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
f8f8 would indicate a mounted C and D drive ? I assume you talk about
the DS:BX pointer.
(as dosbox points to the table where these are stored.... maybe they need to be copied to a location and then point to it. Dunno.)
They are stored for all drives in onetable.
Water flows down the stream
Reply 4 of 16, by DoomWarrior
yeah true DS:BX sorry!
if i mount my cdrom to E:\ it works to! 🤣
after int21:1C there is 02 in BL
then he mov BX, [BX]
then he got F8F8 (with C:\, D:\) and 00F8 (with C:\ E:\)
if there is a floppy in D:\ -> F0F8
so i think your are right. Increasing the media to 16bit ?
edit: i think i have the sucker
Boot Sector (since DOS 2.0) […]
Offset Size Description
13 word number of total sectors (0 if partition > 32Mb)
15 byte media descriptor byte
the silly question is this cmp a bug or a feature 😉
so the game is only installable on partitions bigger then 32MB.
But the game only need 8MB 😵
Reply 5 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
hmm. I don't know.
I'm not sure if that is the actual byte used by that call. (as that isn't the bootsector the call inquiries about.)
I think wd knows it, as the location of the dos tables was determined by him to get windows runinng.
Reply 6 of 16, by wd
Rank DOSBox Author
DOSBox Author
I think the returned id-byte is part of the dpb (which
is not present in dosbox, just the byte itself) so
the assumption that the id-byte is followed by a zero
might be correct, it's something like "drive accessed".
Reply 7 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
sounds familiar. Isn't that the byte people can use to see if the floppy got changed as well ? as the dpb needs to reread from disk in that case.
Reply 9 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
dpbMedia db ? ; Media descriptor
dpbFirstAccess db ? ; 0FFh = medium in drive not accessed
yeps those 2
The first is your number.
the second can be 0. (better said if FF then medium not accessed. Some way to detect a diskchange)
Reply 11 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
for fixed disks it does indeed make little sense, however for floppies... (I might be confused with a different Call, but I remember having read somethink like this once.)
Reply 12 of 16, by wd
Rank DOSBox Author
DOSBox Author
I don't think it serves too well to detect floppy changes,
as it (should?) report disk/floppy access only, not the
changes.
But either way, reserving words for the id-byte with the
high part set to zero might work well.
Reply 13 of 16, by DoomWarrior
now a stupid question, wouldn't it be better to implement the hole dpb thing? because i think there are some other calls point to it ?
Reply 15 of 16, by DoomWarrior
ok here a fix for it...
    dos_files.cpp.diff
    707 Bytes
    293 downloads
    diff for Pinball 3D Installer fix
Reply 16 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
I don't think that will always go allright. As you essentially change what's on ds:bx.
