First post, by ih8registrations
Just reply to this thread on what speed improvement you get.
exe & diff are attached.
    fast.diff
    2.46 KiB
    288 downloads
    dosbox.exe
    1.21 MiB
    299 downloads
Reply 3 of 10, by DosFreak
Haven't tested that much but it seems the same as normal CVS to me.
Do you notice a difference yourself ih8?
Make your games work offline
Reply 4 of 10, by ih8registrations
Yes. Idle cpu utilization halved, increase cycles from a little to a lot depending on the game. My system being an athlon xp 2700, 256k l2. I watch cpu usage with process explorer http://www.sysinternals.com/Utilities/ProcessExplorer.html running dosbox windowed on 98se.
Reply 5 of 10, by DosFreak
Odd, I could have swore that DosBox was close to 0% @ the CLI on my 2800 in earlier builds. Now after reading your comment I loaded up the latest CVS and it seems to hang around 32%. Using your build it seems to be about half that much. Interesting....
Quake v1.08
320x200
Your CVS
42000 cycles=95-99%
Ordinary CVS
40000 cycles=95-99%
640x480
Your CVS
68000=95-99%
Ordinary CVS
48000=95-99%
Duke Nukem 3D
320x200
Your CVS
31000=95-99%
Ordinary CVS
32000=95-99%
640x480
Your CVS
42000 cycles= 95-99% CPU
Ordinary CVS
33000 cycles=95-99% CPU
Reply 6 of 10, by DosFreak
You should probably ignore the 320x scores. I have some background apps running.
Reply 8 of 10, by ykhwong
I found that the patch (a part or all of the contents of fast.diff) is now in cvs repository of dosbox.
But it set the value of frameskip to '1' as I tested. (but dosbox says frameskip=0)
Therefore the overall movement of games is not soft(flexible) for me.)
Reply 9 of 10, by ih8registrations
Crap, I think I see what would cause that, a > instead of a >=, which would make the optimization bullshit(the generated code does get rid a jump but still..).
orig:
if (render.frameskip.count<render.frameskip.max) {
modified:
if (render.frameskip.count>render.frameskip.max) {
so should be:
if (render.frameskip.count>=render.frameskip.max) {
Reply 10 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
🤣. I looked over it as well
Oh boy
I was testing the patch a lot and it kept amazing me 😜
No wonder 😀
hahahhahahahaha
Water flows down the stream
