First post, by cyberaxe
dunno if this has been reported but theres a bug where if you run either the official DOS keyb or an alternative from freedos and so forth and set the layout to UK (unsure if this happens on other layouts) the \ key changes to #
this happens in both the official release and CVS
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
not reported before.
we usually tell people to use keyb.com to fix foreign keyboard layout problems
Water flows down the stream
Reply 2 of 3, by cyberaxe
the official freeDOS keyb doesnt change # to \ however does change DEL to . though unsure if thats the fault of dosbox or the keyboard.sys for freedos keyb
DOS Keyb, Mkeyb Xkeyb and theres another one aswell all exsibit the \ to # problem
