First post, by DrMurke
Hi!
I'm running a Debian Linux system with XOrg 6.8.2 and Kernel 2.6.11 and tried to make dosbox run with good old qbasic. It all went well with using the standard Debian package, but since I'm using Xorg I needed the "userscancodes" option form the CVS version to make all keyboard keys work with dosbox.
Now running the CVS version I have the problem, that after loading the Keyboard driver keyb.exe from FreeDOS, qbasic does not start anymore. When I type "qbasic.exe" on the command line simply nothing happens, but a new prompt appears.
It even looks like no application at all is running, because even "mount" or "config" give no output at all, not even error messages.
I would have really liked to give you some debugger output, but I just don't know, where to start, because I don't see any erros messages or something to start searching.
Does anybody have a clue?
Do you need more data? When yes, which?
