First post, by sevilla.larry
I downloaded DOSbox 0.63. Installed it.
Then try to run Lemmings (original version)
Normally, I play it at Full Screen Mode (Alt-Enter).
When I make mistakes, I normally press ESC to go back then play again.
There are times when the program will go to the Main Menu (of Lemmings), there it will hang up. (this is the bug)
By pressing Alt-Enter twice (Window Mode, then back to Full Screen Mode), the program proceeds normally.
I have Windows XP SP2, AMD Duron 1.3, 768MB RAM, 200GB HD.
Hope this bug will be corrected...
Larry
