Universal Binary for OS X?
Reply 40 of 55, by eobet
Aww, no love for the OS X version, it seems. 🙁
Well, not from me either, I must confess... I still don't want to install Windows via boot camp to run speed tests (going to wait until Vista).
However, I have recently downloaded a universal binary of something called SDLMame (some sort of Mame port for OS X). Compared to Mame32, it is also DOG SLOW! I mean, even Bubble Bobble had extreme sound sutter and graphic slowdown, despite me downloading the very lastest universal binary SDL framework (which was a requirement for SDLMame).
This makes me think that something is terribly, terribly wrong with the universal binaries of SDL...
Reply 41 of 55, by neowolf
eobet wrote:
Aww, no love for the OS X version, it seems. :( […]
Sounds like you might have better luck running MacMAMW under Rosetta. http://www.macmame.org/
"Omne ignotum pro magnifico"
Reply 42 of 55, by Arbee
There is no such thing as a Universal binary of SDLMAME. You compile it customized and optimized for your own processor on your own machine. Note that the first release did not enable compiler optimizations, and between that and OpenGL mode the current builds are between 5 and 20 times faster on G5 and Intel Macs - you can run Killer Instinct full speed with sound on an Intel Mac Mini @ 1.66 GHz, for example.
PS: http://rbelmont.mameworld.info/
Reply 43 of 55, by MiniMax
Rank Moderator
Moderator
I am not sure if this is "universal" or not, but perhaps??
Cocoon Wrapper for DosBOX
_________________
Reply 44 of 55, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
lookls more like a frontend. I'm not sure!
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 45 of 55, by eobet
Hello there! 😀
If I remember correctly, I downloaded it from the following site:
http://www.ltc.lu/enseignants/carlo.noben/
Ok, so it's an old unofficial build without those optimizations then?
EDIT: I just downloaded an old 1.03 intel build of something called XmameRnSK and it was much faster than the SDLMame from the site above, so I guess something was wrong with that build!
Reply 46 of 55, by nakor
Has there been a resolution to the Intel MacOSX dosbox problems? I have had the same problems with it noted here: very poor performance, and an inability to compile from source (I get the "register clobbered" error). I wish I knew more about OSX development so I could help out. Does the CVS have a patch for the "register clobbered" error? Was the proper fix ever determined?
Thanks
Reply 48 of 55, by Qbix
Rank DOSBox Author
DOSBox Author
we have almost fixed the dynamic core issue. Some persons are testing the code.
The build will be ppc only again I think. Depends a bit on which people are available/willing to make build when a release is made.
Water flows down the stream
Reply 50 of 55, by wd
Rank DOSBox Author
DOSBox Author
Maybe you could write a short mail to the developer address, so Qbix
has the contact information when it might be needed.
I'll try to commit the changes somewhen during the next week,
if problems with it should arise just note them here (or if it works 😀 )
Reply 53 of 55, by hexstar
The latest intel version is 0.63 and it runs my games fine...all except the dynamic core doesn't work when running a game that uses the emulated sound card as it causes Dosbox to crash and so you have to use the normal core instead... dynamic core crashes with this error:
Host Name: macminis-computer
Date/Time: 2006-11-27 21:34:05.633 -0800
OS Version: 10.4.8 (Build 8L2127)
Report Version: 4
Command: DOSBox
Path: /Applications/DOSBox-0.63-1/DosBox.App/Contents/MacOS/DOSBox
Parent: WindowServer [57]
Version: 0.63-1 (???)
PID: 1998
Thread: 0
Exception: EXC_BAD_INSTRUCTION (0x0002)
Code[0]: 0x0000000d
Code[1]: 0x00000000
Thread 0 Crashed:
0 dyld 0x8fe12f84 stub_binding_helper_interface + 18
1 <<00000000>> 0x00000000 0 + 0
2 DOSBox 0x00083711 0x1000 + 534289
3 DOSBox 0x000797e1 0x1000 + 493537
4 DOSBox 0x0007a553 0x1000 + 496979
5 <<00000000>> 0x185821b0 0 + 408428976
6 DOSBox 0x0000245b 0x1000 + 5211
7 DOSBox 0x00002668 0x1000 + 5736
8 DOSBox 0x00003632 0x1000 + 9778
9 DOSBox 0x000f59b6 0x1000 + 1001910
10 DOSBox 0x000f27e6 0x1000 + 989158
11 DOSBox 0x000efb6c 0x1000 + 977772
12 DOSBox 0x000f1201 0x1000 + 983553
13 DOSBox 0x000f0934 0x1000 + 981300
14 DOSBox 0x0009d73c 0x1000 + 640828
15 DOSBox 0x000fb637 0x1000 + 1025591
16 com.apple.Foundation 0x925e3207 _nsnote_callback + 230
17 com.apple.CoreFoundation 0x908523f6 __CFXNotificationPost + 345
18 com.apple.CoreFoundation 0x90849c11 _CFXNotificationPostNotification + 600
19 com.apple.Foundation 0x925db860 -[NSNotificationCenter postNotificationName:object:userInfo:] + 121
20 com.apple.Foundation 0x925e2755 -[NSNotificationCenter postNotificationName:object:] + 55
21 com.apple.AppKit 0x9324ee94 -[NSApplication _postDidFinishNotification] + 124
22 com.apple.AppKit 0x9324ed7e -[NSApplication _sendFinishLaunchingNotification] + 67
23 com.apple.AppKit 0x9324e87d -[NSApplication(NSAppleEventHandling) _handleAEOpen:] + 273
24 com.apple.AppKit 0x9324e448 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 96
25 com.apple.Foundation 0x925e8ef1 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 447
26 com.apple.Foundation 0x925e8d1b _NSAppleEventManagerGenericHandler + 91
27 com.apple.AE 0x91515fb5 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 147
28 com.apple.AE 0x91515ee6 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 44
29 com.apple.AE 0x91515db2 aeProcessAppleEvent + 190
30 com.apple.HIToolbox 0x92dca340 AEProcessAppleEvent + 37
31 com.apple.AppKit 0x9324c63d _DPSNextEvent + 1044
32 com.apple.AppKit 0x9324c056 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 137
33 com.apple.AppKit 0x93245ddb -[NSApplication run] + 512
34 DOSBox 0x000fbd8b 0x1000 + 1027467
35 DOSBox 0x000023de 0x1000 + 5086
36 DOSBox 0x000022f9 0x1000 + 4857
Thread 1:
0 libSystem.B.dylib 0x90037697 mach_wait_until + 7
1 DOSBox 0x00113d7e 0x1000 + 1125758
2 DOSBox 0x00113dbe 0x1000 + 1125822
3 DOSBox 0x00102e08 0x1000 + 1056264
4 DOSBox 0x00111207 0x1000 + 1114631
5 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 2:
0 libSystem.B.dylib 0x90009857 mach_msg_trap + 7
1 com.apple.CoreFoundation 0x908292f3 CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x90828b0e CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x9145c41e HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x9145c239 CAPThread::Entry(CAPThread*) + 93
Thread 3:
0 libSystem.B.dylib 0x90048a47 semaphore_timedwait_signal_trap + 7
1 com.apple.audio.CoreAudio 0x9146965c CAGuard::WaitFor(unsigned long long) + 212
2 com.apple.audio.CoreAudio 0x9146957e CAGuard::WaitUntil(unsigned long long) + 66
3 com.apple.audio.CoreAudio 0x91467efa HP_IOThread::WorkLoop() + 690
4 com.apple.audio.CoreAudio 0x91467c43 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
5 com.apple.audio.CoreAudio 0x9145c239 CAPThread::Entry(CAPThread*) + 93
6 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 4:
0 libSystem.B.dylib 0x90024427 semaphore_wait_signal_trap + 7
1 ...pple.audio.units.Components 0x700174ca DLSMusicDeviceEntry + 10858
2 ...pple.audio.units.Components 0x70017303 DLSMusicDeviceEntry + 10403
3 ...pple.audio.units.Components 0x70017192 DLSMusicDeviceEntry + 10034
4 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000003 ebx: 0x000832cd ecx: 0x00000bb8 edx: 0x0017b024
edi: 0x00000040 esi: 0x018e3520 ebp: 0xbfffba24 esp: 0xbfffb9c4
ss: 0x0000001f efl: 0x00010282 eip: 0x8fe12f84 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x17afff DOSBox 0.63-1 (???) /Applications/DOSBox-0.63-1/DosBox.App/Contents/MacOS/DOSBox
0x189e1000 - 0x18a52fff com.DivXInc.DivXDecoder 6.2.5 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x18aa8000 - 0x18aadfff com.apple.audio.AppleHDAHALPlugIn 1.2.4 (1.2.4a21) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x70000000 - 0x700f9fff com.apple.audio.units.Components 1.4.3 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe49fff dyld 46.9 /usr/lib/dyld
0x90000000 - 0x9016ffff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901bf000 - 0x901c1fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c3000 - 0x90200fff com.apple.CoreText 1.1.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90227000 - 0x902fcfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031c000 - 0x90770fff com.apple.CoreGraphics 1.258.38 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90807000 - 0x908cffff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9090d000 - 0x9090dfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9090f000 - 0x90a02fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a52000 - 0x90ad1fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90afa000 - 0x90b5efff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bcd000 - 0x90bd4fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bd9000 - 0x90c4cfff com.apple.framework.IOKit 1.4.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c61000 - 0x90c73fff libauto.dylib /usr/lib/libauto.dylib
0x90c79000 - 0x90f1ffff com.apple.CoreServices.CarbonCore 682.15 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f62000 - 0x90fcafff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91002000 - 0x91040fff com.apple.CFNetwork 129.18 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91053000 - 0x91063fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x9106e000 - 0x910ecfff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91121000 - 0x9113ffff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9114b000 - 0x91159fff libz.1.dylib /usr/lib/libz.1.dylib
0x9115c000 - 0x912fbfff com.apple.security 4.5.1 (29002) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913f9000 - 0x91401fff com.apple.DiskArbitration 2.1.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91408000 - 0x9142efff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91440000 - 0x91447fff libbsm.dylib /usr/lib/libbsm.dylib
0x9144b000 - 0x914c1fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91512000 - 0x91512fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91514000 - 0x9153ffff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91552000 - 0x91626fff com.apple.ColorSync 4.4.8 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91661000 - 0x916d4fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91702000 - 0x917abfff com.apple.QD 3.10.21 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917d1000 - 0x9181cfff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9183b000 - 0x91851fff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9185d000 - 0x91877fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91881000 - 0x918befff com.apple.LaunchServices 181 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918d2000 - 0x918defff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918e5000 - 0x91920fff com.apple.ImageIO.framework 1.5.0 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91932000 - 0x919e4fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a2a000 - 0x91a40fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a45000 - 0x91a63fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a68000 - 0x91ac6fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91ad8000 - 0x91adcfff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ade000 - 0x91b5bfff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b5f000 - 0x91b9cfff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91ba2000 - 0x91bbcfff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91bc1000 - 0x91bc3fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91bc5000 - 0x91bc5fff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91bc7000 - 0x91c55fff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91c5c000 - 0x91c5cfff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91c5e000 - 0x91cb7fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91cc0000 - 0x91ce4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91cec000 - 0x920f5fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9212f000 - 0x924e3fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92510000 - 0x9258dfff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x925ce000 - 0x927fefff com.apple.Foundation 6.4.7 (567.28) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9290a000 - 0x929e8fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92a05000 - 0x92af2fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b02000 - 0x92b19fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92b24000 - 0x92b7cfff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92b90000 - 0x92b90fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92b92000 - 0x92ba2fff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bb1000 - 0x92bb9fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92bbf000 - 0x92bc4fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92bca000 - 0x92c5bfff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c6f000 - 0x92c72fff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c75000 - 0x92c93fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92ca5000 - 0x92cabfff com.apple.print.framework.Print 5.1 (192.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92cb1000 - 0x92d14fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d38000 - 0x92d79fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92da0000 - 0x92dadfff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92db4000 - 0x92db9fff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92dbe000 - 0x930b2fff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x931b8000 - 0x931c3fff com.apple.opengl 1.4.12 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93233000 - 0x93233fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93235000 - 0x938ebfff com.apple.AppKit 6.4.8 (824.42) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93c6c000 - 0x93ce6fff com.apple.CoreData 90 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93d1f000 - 0x93dd7fff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e19000 - 0x93e19fff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93e1b000 - 0x93fedfff com.apple.QuartzCore 1.4.9 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9403e000 - 0x9407ffff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x94087000 - 0x940c1fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9424a000 - 0x94259fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94260000 - 0x9426bfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x942b7000 - 0x942d1fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x942d7000 - 0x94590fff com.apple.QuickTime 7.1.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9643c000 - 0x9643cfff com.apple.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96a9e000 - 0x96aa3fff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97d84000 - 0x9886efff com.apple.QuickTimeComponents.component 7.1.3 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
but other then that it works great 😀
Reply 54 of 55, by hexstar
oh also the particular game I was running in the dynamic core that uses the soundcard and caused this crash repeatedly when using the dynamic core is called Jill of the Jungle by epic megagames
