First post, by Dominus
DOSBox Moderator
- DOSBox Moderator
I'm writing a guide on how to install Ultima 7 via dosbox and thought it'd be easy to also mention that you could also easily mount floppy images instead of the real floppys but apparently I forgot that this is not possible (at least not without some trickery by renaming the floppy image everytime the installer asks for a new disk).
Is this planned to be added at some point?
I know it works for the BOOT command but that doesn't help if you can't boot it 😀
