First post, by NeilC
I'm working on an old dos app, trying to modify it to run sucessfully in dosbox, however i've run across an issue. It seems that it uses a native function for which i don't have the source which requires the environment variable comspec to be set, however it always returns that it cannot find it in the environment.
I can use a getenv type function to return it within my app, and it has the right value, so the function must use some other call, is there a way i can find out what the call is or why this is failing?
Has anyone else ever heard of this kind of issue with environment variables?
