First post, by sry
What compiler is used to create the Windows executables that are released to the public? Thank you.
Scott
Reply 3 of 5, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Yes. I think that QBIX crosscompiles the Windows releases on Linux, but you can compile in Windows using MINGW (contains gcc + other utils). Search a bit here or check WIKI for details...
Mirek
