First post, by tw261
I've used dosbox on several other systems before without issue but it has been a while since I've installed it on a Linux system, so bare with me if I am missing something obvious...
I just installed FC5 on an older PC and then installed dosbox 0.65 with yum (command was "yum install dosbox") but when I try to run dosbox either from a command prompt or from the Gnome Applications->Accessories->DOSBox menu, I get the same result: I only get a single dosbox window that is blank and appears to be hung. It accepts no input and the only way to close it is to "killall -9 dosbox"
Thinking that perhaps this was a problem with this package, I did a search on the net and found no similar issue. I did find people complaining about dosbox causing a kernel fault that killed their OS, but not just a hung dosbox in FC5. So, I decided to compile from source. My compiled app has the same issue...
Am I doing something wrong? Did I skip a step? maybe I need to have a dosbox.conf file with the right settings? I've tried a few things and keep getting the same result. I seem to remember this happening to me a couple years ago when I first tried to run .60 or .58 (I think) on Windows but I can't remember what I did to get it working...
Please help! If this is an FC5 issue, I'd like to know soon before I bang my head against this much longer. If I'm just missing a step, someone please point out my stupidity. 😀
Thanks!
-Tim
