First post, by TeaRex
Hello,
in recent days something in the CVS seems to have broken dos32a. Is this only me or is it a known problem? I'm running DOSBox on SuSE 10.1, compiled with gcc 4.1.0. dos4gw seems to work fine.
EDIT: I should add that the symptoms are: a slightly garbled statup message immediately followed by a lock-up (of the emulation, I can still close the DOSbox window without problems). The problem occurs independently of whether I run dos32a on some exe file or just so.
The problem shows up in both normal and dynamic core.
Best wishes,
tearex
