OSX Bug: Incorrect executable specified in Info.plist file
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby aPinecone » 2006-7-31 @ 05:27
Hi,
I've recently (yesterday) downloaded the latest version of DOSBox for OSX, and noted that double-clicking the application starts correctly from the mounted .dmg file, but does not start at all once copied out of the mounted .dmg file.
The issue is with DOSBox.app/Contents/Info.plist, where the executable to run is specified as:
Code: Select all
<key>CFBundleExecutable</key>
<string>DOSBox</string>
Whereas it should be specified as
Code: Select all
<string>DosBox</string>
...which fixes the problem.
This issue occures because Mac OS X allows users to have a case-insensitive filesystem, but it also allows a case-sensitive filesystem, where "DOSBox" and "DosBox" are different files.
aPinecone
Re: OSX Bug: Incorrect executable specified in Info.plist file
Postby wd » 2006-8-02 @ 20:21
Hm but renaming the executable to DOSBox would work as well?
As that's how it is spelled officially.
Maybe that can be taken into account next time, thanks for noting this!
wd
DOSBox Author
Return to DOSBox Development
Who is online
Users browsing this forum: knowledge [bot] and 1 guest
