First post, by marker0077
I mounted a special drive specifically for the path. I use this for shortcut commands, i.e. "e" exits the prompt, "cfg %1" will create a config file for whatever filename, etc; etc.
Problem is, the path doesn't work. I set the path to the z:\ & the y:\, I type path at the command prompt to make sure it's set (which it is) & it still does not work.
No signature
