First post, by deeped
Hi there,
you guys know the DOSbox emulates the AdLIB/FM sounds... this question is for the developers: how to do it by? By DirectSound? (I only interested on Win32 platform). If so, how can I "borrow" it from the source? Which source files uses and how? I used to deal with Adlib in DOS platform. I know its can be used by 388h, 389 ports. Question is again: how to use it to make sounds by writing 388, 389 "ports"?
