First post, by japheth
japheth
Offline
Hello,
the following code snippet to detect the cpu type has a problem running under DEBUG in DosBox:
pushf
pop ax
or ah,70h
push ax
popf ;<--- here DEBUG looses control of debuggee in DosBox
pushf
pop ax
could this be fixed?
used DosBox CVS build from 12.11.2006 for the test.
