Magic Carpet crashing (CVS)
Reply 80 of 91, by MiniMax
Rank Moderator
Moderator
MiniMax wrote:
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 85 of 91, by MiniMax
Rank Moderator
Moderator
Seems like you missed this too:
MiniMax wrote:
(and don't just read it - follow it too).
MiniMax wrote:
5. Switch to the D: drive and install the game (to C:)
C:\>D:
Have a look at the files with the dir command, and see if you can spot an install or and a setup program or whatever the command to start the installation is called. Check your Manual/Installation Guide for MyGame for the exact command to use.
_________________
Reply 87 of 91, by MiniMax
Rank Moderator
Moderator
Combover wrote:
Sorry, I must have overlooked that... here's what I typed: imgmount d /path/to/cd/image.iso -t iso d: cd carpet carpet […]
d:
cd carpet
carpet
then chose no sound/ no music
I see no mount C .............
If you followed my guide (as you said you did), there should be one. So you are 1) Either withholding information, or 2) Lying. Why you would do either, I seriously don't understand.
_________________
Reply 88 of 91, by Kippesoep
There is indeed no install file for MCCD Plus. It automatically created a directory C:\CARPET.CD to store its info. It might actually run without a C drive present...
My site: Ramblings on mostly tech stuff.
