First post, by MiniMax
Rank Moderator
Moderator
With 0.70 the way DOSBox locates its config files has changed. And we know have the multi-conf option too.
I think it would be valuable, if the status window would list the location of each config file that is being read.
_________________
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
it prints out the ones reads as far as I know.
Not the locations it tries though.
Water flows down the stream
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
Hmm, yes I see that it emits CONFIG status lines. But then I think I have found an error.
In a Windows CMD I set HOME="C:\Documents and Settings\MiniMax". In %HOME% I have a tiny dosbox.conf with cycles=321.
I chdir to C:\Programs , and start DOSBox-0.70\dosbox.exe, and all I get in the status window is
CONFIG: Using default settings. Create a configfile to change them.
And my cycles stay at the default 3000.
_________________
