First post, by loicp
Hello,
First, thanks for this awesome software, I know it's not very specific to games, but dosbox already help me to develop/debug an home made ISA card I've build to play with electronics 😀
I have a question about memory dump : is it possible to dump to disk executable's image in memory to disk with cpu registers contents after n instructions ? like run foo.exe, run 200 instructions then dump memory to disk ?
cheers,
Loic
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
yes. with some creativity.
Commands you will need
Debugger version of dosbox
memdumpbin seg:ofs size
LOG amountofinstructions
Good luck.
Water flows down the stream
Reply 2 of 6, by loicp
Thanks for your quick help 😀
I will try them as soon as possible
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
What do you want to do exactly?
Reply 4 of 6, by loicp
Launch my program, see which n instructions were performed with registers's contents, and the final contents of memory after the instructions, here is my goal
Reply 5 of 6, by wd
Rank DOSBox Author
DOSBox Author
Yes, but why? Just curious 😀
Reply 6 of 6, by loicp
To play with my ISA card. I'm trying to set/get various bits.
For the moment I'm only playing with simple logic gates, and I'm very happy to see that I can read on my card the result of a very simple 'electronic' operation like 0 AND 1 makes 0
