First post, by Malor
I've been trying to run this one, on and off, for years. Finally figured out why it wouldn't run: it doesn't like DOSBox EMS. With EMS enabled, in dynamic mode it will peg the processor. In normal mode, it makes repeated pairs of small clicks, as though it's initializing the soundchips over and over. Blank screen in both cases, requiring a DOSBox exit/restart.
If you disable EMS, it works great.
I added this as a note to the compatibility database, and thought I'd pass along the bug report, if anyone wants to take a look at it. If not, no biggie, it does run.
