First post, by oneirotekt
- Member
Cross-posted from the Ubuntu forums because it didn't get an answer there:
There is a bug in the version of libSDL in the Feisty repositories that causes this bug in DOSBox. There's a simple fix for Windows users, which is to use a version of SDL.DLL compiled from the latest source (which a guy on the Vogons forums has so kindly made available). I would like to use the analogous fix in Ubuntu, but I'm not 100% clear on how to go about it.
I notice that there is a special version of SDL for Debian / Ubuntu, and I was wondering if I was treading into rough territory here - I was able to get the latest SDL to build, so I'm wondering how I get DOSBox (and only DOSBox, so other apps don't screw up) to use that version of the lib rather than the main one in /usr/lib ?
