First post, by Metal Overlord
Hey everyone, new guy here. Lovely avatars you have here. 😁
Anyhow, as for my question; I've searched the boards and tried it myself, I must admit that I am awful at programming anything at all.
So I'm making a nifty little launch tool to go with my upcoming Spear of Destiny-mod, the prequel to Wolfenstein 3D, and so far everything works surprisingly swell. I've amazed myself and my poor skills by successfully having the launcher run the game normally, with debugmode parameter, launch the website up in the default browser and by having it launch through VDMSound with a .bat-shortcut. All done with good ol' The Games Factory too. 😁
I want to add in support for running the game through DOSBox, if the program is installed of course. I tried writing a .bat-file linking to dosbox with some parameters edited, but it just opens the command prompt and closes it again, so I've obviously done something wrong on the way.
So I was hoping that some kind soul on these boards might be able to help me make a .bat-file that runs my program through DOSBox, from its directory where the user has installed DOSBox if present on the system.
Any help or advice is much appreciated, as the mod's nearly ready for release. 😀
Visit http://www.tgoel.tk/ for the latest info on my remake of my Spear of Destiny-mod.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
take a look at the railroads tycoon deluxe version of 2kgames. (freeware download)
I think it incorperates what you want
Water flows down the stream
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
I do this:
@       echo off
if not defined dosbox (
set dosbox=%ProgramFiles%\DOSBox-0.70\dosbox.exe
start "DOSBox" "%dosbox%" -noconsole %*
_________________
Reply 3 of 3, by Metal Overlord
Ah, now I got the hang of it. Thanks a lot, guys. 😁
