First post, by Myloch
Found this problem with pcspeaker and sb16 enabled in configfile. If you run games like "mike ditka ultimate football" or "metal mutant", digitized sound effects are corrupted... but this does not happen if I disable sb16 emulation. I think there are some games that use soundcard and pcspeaker at the same time and the bug happens in this particular situation. Let's discuss about it.
Reply 1 of 11, by HunterZ
Actually this is a long-standing issue. I believe what is happening is that the games are trying to use the OPL synthesizer chip as a 1-bit DAC similar to the PC Speaker. However, this is very timing intensive and DOSBox does not handle it accurately enough.
It works for PC Speaker because DOSBox implemented some sort of buffering system for PC Speaker data.
Another game to test this with is Wizardry 7. If you use PC Speaker for digitized sounds it works fine. If you use Adlib/SB it doesn't (at least, I'd presume it doesn't - I haven't tested for a while because I haven't played with DOSBox lately).
Reply 2 of 11, by eL_PuSHeR
Interesting. I had heard there were some games using OPL chips to act as a DAC to play digitised sounds.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 11, by frip
hmm is this why Xwing doesnt play some samples well?
Recorded a sample from p166 machine with SB16 and compared to dosbox v0.72 (changing laser firing mode)
Also notice the waveform for dosbax doesnt play heaps of the negative part.
Reply 7 of 11, by wd
Rank DOSBox Author
DOSBox Author
Well it's annoying me as well, but i'm not sure why it happens.
It seems like the "real thing" (opl itself or some other component?)
automatically adjusts the level so the waveform looks fine. I've implemented
something like that for dosbox as well, yet tuning it seems quite hard
(it doesn't really improve the sound as well).
Maybe somebody has/can find information about why this happens.
Reply 8 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
hmm it looks like the negative part isn't accounted for at all.
Maybe a sign thing
Water flows down the stream
