First post, by tricky_trev
Hi guys,
Any ideas on how to change the mouse cursor (blinking or intensity style) behaviour when in M_TEXT mode?
cheers and thanks,
trev.
Reply 4 of 13, by tricky_trev
all i want is to stop the mouse cursor blinking because you loose track of where it is when you move the mouse. but ideally it should also highlight the characther underneath it too.
i suppose i'll have to find out how to program it, unless you know something easy off the top of your head?
Reply 8 of 13, by tricky_trev
in vga_attr.cpp, i tried to play with the mode control register 0x10 (particularly bit 3), but that didn't make anything change.... no matter what the cycles of the cpu is, the blink rate is still constant, so it seems to be interrupt driven. perhaps it is programed in the app after all...
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
Well suppose the app uses that attr blinking bit. Try always clearing it
on writes to that reg, or always setting it and see if something changes.
Otherwise they might just use a block cursor.
Reply 10 of 13, by tricky_trev
i think the app uses it's own cursor, since i can AND the mode control register with 0x0 and nothing changes... wierd as something should change. perhaps i'm not doing it right, but i'll keep looking....
Reply 12 of 13, by tricky_trev
The following temporary mod had no affect:
void VGA_SetBlinking(Bitu enabled) {
Bitu b;
LOG(LOG_VGA,LOG_NORMAL)("Blinking %d",enabled);
//if (enabled) { //TREV
// b=0;vga.draw.blinking=1; //used to -1 but blinking is unsigned
// vga.attr.mode_control|=0x08;
// vga.tandy.mode_control|=0x20;
//} else {
b=8;vga.draw.blinking=0;
vga.attr.mode_control&=~0x08;
vga.tandy.mode_control&=~0x20;
for (Bitu i=0;i<8;i++) TXT_BG_Table[i+8]=(b+i) | ((b+i) << 8)| ((b+i) <<16) | ((b+i) << 24);
