First post, by mysoft
im not sure for why reason i have not seen that before, maybe i miss this, but not found anythin worth in the search, then...
isnt a good idea, make one INTERNAL, dos extender, to substitute the DOS4GW or DOS32A, but that will work, internally to not need emulate the extender program, i guess that this can speed-up significantly many, if not all extended games, comments?
