First post, by ErikGG
- Member
Creating a bin/cue using ISOBuster for my Tomb Raider CD resulted in an unuseable cue file. But this is ISOBusters fault.
Anyways, after fixing the cue from ISOBuster (setting mode 1 and changing CDR to Audio), I mounted the Tomb Raider cue file using ImgMount with the -t iso flag.
Starting DOSBox with the conf file resulted in a crash
(With the Windows XP "Let MS know about the error maybe we can fix this in the future" dialog).
After checking the cue file again, I found that ISOBuster had created a cue file not "linked" to the bin file.
FILE "CD.bin" BINARY
While the bin file was called "track1.bin".
Changing the CD.bin to 1_trackk1.bin fixed it.
Erik.
