First post, by jcdutton
Does anyone know of any DOS based timing programs that can time the receipt and transmission over the serial port.
I need to do tests so that the serial data leaves and arrives in DOSBOX and DOSEMU at exactly the same time as it would on real hardware.
This is due to some very old DOS application that I need to run.
