First post, by ih8registrations
Trying to find information on how NMI is invoked. Below would be what to do once triggered, but how/where to trigger..
I put this in cpu.cpp, check in normal_loop.
bool CPU_NMI=false;
bool CPU_NMI_Check(void) {
if (CPU_NMI) { // && RealGetVec(0x02)) {
CPU_SW_Interrupt(2,reg_eip-SegPhys(cs)); // GetIP());
CPU_NMI=false;
return true;
return false;
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
NMI should be a hw interrupt, better put it into PIC_RunQueue like the regular irq's.
Triggering is through the NMI line of the cpu, i only know it was used to
signal memory errors (parity check failure) to basically halt the pc.
Reply 3 of 5, by ih8registrations
Yes, I understand the physical connection, that the cpu has two IRQ pins, one hooked up to the PIC, the other the NMI. I also considered sticking it in into the PIC, but didn't think you guys would be interested in a hack-esk implementation. The source for the interwave sbos version is even available, http://alsa.cybermirror.org/datasheets/gus/amd960214.tar.gz, yet I've managed to miss how they're invoking it(look at loader.c, setup_nmi(), test_nmi(), and search for nmi in general). I see them enabling NMIs, installing their test nmi handler for INT 2, but miss how they're triggering the NMI for their nmi count to increment. Interstingly enough, at one time the source for the original GUS/MAX was available but has unfortunately since gone MIA. In case you're wondering why bother, when it worked, SBOS would often sound better than OPL playback, ultrabots being an example; sounding cool instead of dinky.
