First post, by madcrow
... found using Borland Paradox 4.5
I know that Databases aren't games, but when trying to use one, I encountered something odd: Borland Paradox 4.5 always seems to crash and burn within a minute or so of being started, always with the same error message: "Unexpected condition: GP 76fc AT PARADOX:03:70c1 -- Leaving Paradox"
I'm using vanilla 0.72 with standard settings, so there may be some tweak to work around this (and if there is, please share" , but otherwise I may have uncovered some kind of bug in the emulated CPU.
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
You could try different CPU emulation methods in DOSBox.
Before running your program, issue of the commands:
C:\>core simple
C:\>core
C:\>paradox
C:\>core normal
C:\>core
C:\>paradox
C:\>core dynamic
C:\>core
C:\>paradox
_________________
Reply 2 of 3, by madcrow
MiniMax wrote:
You could try different CPU emulation methods in DOSBox. […]
C:\>core simple
C:\>core
C:\>paradox
C:\>core normal
C:\>core
C:\>paradox
C:\>core dynamic
C:\>core
C:\>paradox
Tried that and Paradox appears to crash the same way no matter which core I use. Other Borand programs from the area (dBase IV 2.0, dBase V and Quattro Pro 5) seem to work fine, so I doubt this is a manifestation of the "Borland runtime libraries hate fast CPUs" bug, so I'm totally puzzled as to what it might be.
