actually without Qbix's immediate and active assistance (thank you so much) chances were no log was going to come, as at first after installing the pdcurses libraries using them turned out to be quite problematic to me, since msys would refuse to locate them...(this is Windows)
I don't know if this might somewhen matter to someone else, but this might be helpful info if only for other inept users (like me), after all if Forums are aimed to diffusing competence, hence are postulating incompetence, and you can bet I'm a real expert at inexpertise, so why shouldn't I add here that
after Qbix helped me out,
I still kept on investigating a little more on MinGW/Msys not finding curses.h etc. fumbling for some fix and I guess I found a way after all :
finally used a different pdcurses-2.6.0-2003.07.21-1.exe setup for them, installed over my c:\mingw folder
(as opposed to install into "c:\program files\something" and then trying to fiddle with some export path= expression in msys, and other unlucky previous shots at it)
and finally I could create a cute debug enabled dosbox.exe too ! 😀
OK, so these are the 2 new logs.
I started comparing them, not via a real binary comparison, because it's meaningless imo (I can't trust the timings of 2 separate sessions to be close enough)
but through just a sequence of vertical juxtapositions of the logs' windows (see if it's some use the screens I took...)
By my first glimpse, and by what I can make of it, hoping to avoid uttering an excessive amount of foolishnesses, I'd say the logging of
MSCDEX: IOCTL INPUT Subfunction 0B and get audio track info
gives no sign of a different pattern (compare1.jpg)
The subsequent mscdex calls are identical except on noioctl (music on) side
there are these calls
55075306: MISC:MSCDEX: INT 2F 1510 BX= 0000 CX=0003
55075306: MISC:MSCDEX: Driver Function 03
55075306: MISC:MSCDEX: IOCTL INPUT Subfunction 06
55075306: MISC:MSCDEX: Status : 0300
55075324: MISC:MSCDEX: INT 2F 1510 BX= 0000 CX=0003
55075324: MISC:MSCDEX: Driver Function 03
55075324: MISC:MSCDEX: IOCTL INPUT Subfunction 0C
55075324: MISC:MSCDEX: Status : 0300
unmatched by any in ioctl (compare2.jpg)
They're for
case 0x06 : /* Get Device status */
and
case 0x0C : /* Get Audio Sub Channel data */
Doubtful whether they carry any real significance though.
Probably in 1 day or 2 I'll try to take one more couple of log shots to see what happens.
Use examdiff of diffmerge to automate this process.
Also try getting rid of some unnecessary log output that makes the log file
less readable, like disable the Raising IRQ message (sblaster.cpp).
The logs are indeed equal with respect to the relevant mscdex operations.
It might very well be that everything works fine, just the "play audio" call
is ignored.
Anyway, try adding some more detailed logging at the 0x84/0x85 subfunctions
(maybe for some reason the wrong start address for audio tracks is used).
done
wd wrote:The logs are indeed equal with respect to the relevant mscdex operations.
It might very well be that everything works fine, just […] Show full quote
is ignored.
I tried adding one LOG_MSG here @ subfunction 0x84
1 case 0x84 : { /* Play Audio Sectors */ 2 Bit32u start = mem_readd(curReqheaderPtr+0x0E); 3 Bit32u len = mem_readd(curReqheaderPtr+0x12); 4 if (mem_readb(curReqheaderPtr+0x0D)==0x00) // HSG 5 mscdex->PlayAudioSector(subUnit,start,len); 6 else // RED BOOK 7 mscdex->PlayAudioMSF(subUnit,start,len); 8 LOG_MSG("start: %d, len: %d, subUnit: %d", start,len,subUnit); 9 break; 10 };
I'm not sure whether this is just what you had in mind though
as for subf. 0x85 I've been looking into the implementation of
bool StopAudio()
i.e.
but am unsure as to what to consider worthwhile logging.
Maybe dinfo[subUnit].audioPlay ?
or dinfo[subUnit].lastResult, which can be the return value of StopAudio() and of GetCDInfo() and other functions as well ?
But do they matter anyway ?
Here are the 2 new logs, sorry I didn't try the diffmerge util yet.
In these logs, still nothing there as far as I can see that throws some light.
Are the logs (both) fully reproducable? As the noioctl-one has two additional
audio channel control calls somewhere at the end.
Try checking/logging what CMscdex::PlayAudioSector and CMscdex::StopAudio
actually do, especially if dinfo[subUnit].audioPaused is consistent (so both times
the PlayAudioSector call does start the playback).
And maybe add full logging to case 0x0C : Get Audio Sub Channel data
and case 0x06 : Get Device status of the ioctl input functions.
I will surely add the dinfo[subUnit].audioPaused check as soon as I am able.
There's a point though still lingering here that I'd really love to discuss in advance, for I somehow fear I'm going in circles around the ioctl obsoleteness in Vista, along the lines of the IOCTL_CDROM_READ_Q_CHANNEL issue shown here: http://msdn2.microsoft.com/en-us/library/ms803640.aspx
("Obsolete, beginning with the Windows Vista. Do not use this IOCTL to develop drivers in Windows Vista.")
At the end of both logs there's the sequence
74507455: MISC:MSCDEX: INT 2F 1510 BX= 0000 CX=0003
74507455: MISC:MSCDEX: Driver Function 03
74507455: MISC:MSCDEX: IOCTL INPUT Subfunction 06
74507455: MISC:MSCDEX: Status : 0300
74507473: MISC:MSCDEX: INT 2F 1510 BX= 0000 CX=0003
74507473: MISC:MSCDEX: Driver Function 03
74507473: MISC:MSCDEX: IOCTL INPUT Subfunction 0C
74507473: MISC:MSCDEX: Status : 0300
It makes sense that the status amounts to track playing (or thinking it is in ioctl case) because here's when the music is/ought to be playing and I pack it in closing dosbox at once without exiting the game to spare time.
But how do I know it is (or should be) playing ?
In general, because I know what the game does at this point and in fact noioctl behaves exactly as expected, but from the debugging point of view
I think I do because of the Status variable outcome
(please be patient and forgive my being so slow pedantic and what have you) :
in dos_mscdex.cpp I can start from
1static Bit16u MSCDEX_IOCTL_Input() { 2 ... 3 switch (ioctl_fct) { 4 ... 5 case 0x06 : /* Get Device status */ 6 mem_writed(buffer+1,mscdex->GetDeviceStatus(drive_unit)); 7 break;
via
1// Request Status 2#define REQUEST_STATUS_DONE 0x0100 3#define REQUEST_STATUS_ERROR 0x8000
then
Bit32u CMscdex::GetDeviceStatus(Bit8u subUnit);
then
1static Bitu MSCDEX_Interrupt_Handler(void) { 2 ... 3 // huge switch 4 ... 5 // Set Statusword 6 mem_writew(curReqheaderPtr+3,mscdex->GetStatusWord(subUnit,errcode)); 7 MSCDEX_LOG("MSCDEX: Status : %04X",mem_readw(curReqheaderPtr+3)); 8 return CBRET_NONE; 9 }
cool, this is where the mscdex : status message in the log comes from,
so go ahead to
1Bit16u CMscdex::GetStatusWord(Bit8u subUnit,Bit16u status) 2{ 3 if (subUnit>=numDrives) return REQUEST_STATUS_ERROR | 0x02; // error : Drive not ready 4 5 if (dinfo[subUnit].lastResult) status |= REQUEST_STATUS_DONE; // ok 6 else status |= REQUEST_STATUS_ERROR; 7 8 if (dinfo[subUnit].audioPlay) { 9 // Check if audio is still playing.... 10 TMSF start,end; 11 bool playing,pause; 12 if (GetAudioStatus(subUnit,playing,pause,start,end)) { 13 dinfo[subUnit].audioPlay = playing; 14 } else 15 dinfo[subUnit].audioPlay = false; 16 17 status |= (dinfo[subUnit].audioPlay<<9); 18 } 19 dinfo[subUnit].lastResult = true; 20 return status; 21};
I conclude that if status == 0x0300, bit 8 and 9 set, right ?
this means that in
the line :
takes me to understand that bool playing == TRUE; right again ?
now this bool playing is just coming from GetAudioStatus(subUnit,playing,pause,start,end)
These obsolete-entries are exactly the crucial point, because there is no
information if they are still working or not. It looks like many of them still
work just fine (but might not in later vista/+ releases) as they behave
identical as under xp.
Maybe you could compare the state/return values of
CDROM_Interface_Ioctl::GetAudioStatus under xp and vista (so using the
ioctl interface both times).
My suspect is that just the play back audio function does not start off,
yet does not return failure either.
if the IOCTL business is abandoned, what to do about it ?
Write hatemails to MS or so. The problem is mixing direct sector access
(ioctl needed) with audio capabilities (mm stuff, like sdl does it).
I'm using another pc with win xp home sp2 at this time so hopefully soon I'm gonna recompile and be able to test\compare
BOOL bStat
values in CDROM_Interface_Ioctl::GetAudioStatus()
both under xp & vista (on 2 different machines anyway) and also adding some more log messages as you suggested.
Began to use diffmerge too 😎
Btw, curiosity killed the cat, but what's with these strange comments about forcing SDL_CDOpen() and a SDL bug in
1bool CDROM_Interface_SDL::PlayAudioSector (unsigned long start,unsigned long len) 2{ 3 // Has to be there, otherwise wrong cd status report (dunno why, sdl bug ?) 4 SDL_CDClose(cd); 5 cd = SDL_CDOpen(driveID); 6 bool success = (SDL_CDPlay(cd,start+150,len)==0); 7 return success; 8};
and
1bool CDROM_Interface_SDL::StopAudio (void) 2{ 3 // Has to be there, otherwise wrong cd status report (dunno why, sdl bug ?) 4 SDL_CDClose(cd); 5 cd = SDL_CDOpen(driveID); 6 bool success = (SDL_CDStop(cd)==0); 7 return success; 8};
these comments accordingly are not there in CDROM_Interface_Ioctl::PlayAudioSector() nor in CDROM_Interface_Ioctl::StopAudio()
OK I thought I might as well start posting the fresh outcome with WindowsXP 😎
Splitting the report in two will hopefully make it easier to handle, for any reader as well as for your poor little worn out correspondent 😵 , not to speak I won't be messing with the vista pc until tomorrow 😜
I've been adding quite a few more log messages, hope wd that complies with your idea of full logging attitude (triple 😅 ).
To understand the changes maybe it's better if I detail the log lines I added into
cdrom_ioctl_win32.cpp
and
dos_mscdex.cpp
as per wd's requests when he wrote :
Maybe you could compare the state/return values of CDROM_Interface_Ioctl::GetAudioStatus under xp and vista (so using the ioctl […] Show full quote
Maybe you could compare the state/return values of CDROM_Interface_Ioctl::GetAudioStatus under xp and vista (so using the ioctl interface both times).
actually do, especially if dinfo[subUnit].audioPaused is consistent (so both times the PlayAudioSector call does start the playback).
So here's the new recompiled code, you just lookup the new log lines :
and bringing to you the (hopefully) last and final logs :
brand new ioctl vista log and noioctl vista log to match ioctl xp log of yesterday.
What surfaces ?
Two considerations so far :
I noticed that status (consistently == 214h in ioctl xp && noioctl vista) in ioctl vista starts as well being
241h == 0000 0010 0001 0100b
then abruptly @ line #420 in diffmerge it becomes (and will also stay @ line #450)
A15h == 0000 1010 0001 0101b
it doesn't take much research if you keep in mind CMscdex::GetDeviceStatus() to see the bites 0 and 11 differ, which means failure :
(trayOpen) == (!media) == TRUE;
It seems strange, but that is so.
One step back : I marked the moment the cd music starts or fails (I took note how the debugging window was going during the game, of course) :
well, I noticed the moment the music fails for the first time, is not there @ line #420 where ioctl vista status goes astray, but happened before (@ line #284) and that's a point where the current available variable values e.g. start: 87283, len: 14745, subUnit: 0 are all right,
while status itself has been last checked @ line# 117 and it was the "right" 241h value !
Now I will investigate a bit about these trayOpen and media variables.
They come to CMscdex::GetDeviceStatus() from
GetMediaStatus(), but
surely not from this one :
bool GetMediaStatus (Bit8u subUnit, Bit8u& status);
they come instead from :
just invokes cdrom[subUnit]->GetMediaTrayStatus(media,changed,trayOpen);
don't let me show you this time sdl's
CDROM_Interface_SDL::GetMediaTrayStatus()
which dwells in cdrom.cpp of course where you can check it but it poses no riddles imho, the crucial point of it being the line :
am I just too tired now, or there's an obnoxious bugafter "leadOut)," ????
Where's that instruction ending ?
What if this is messing up the critical mediaPresent value ???
So far, the outcome of comparing ioctl vista and noioctl vista.
The comparison between
ioctl xp and ioctl vista
shows a bunch of functions not being called at all in ioctl vista as may be predictable.
There's really too many of them to be reported here by me, just diffmerge them and see.
It's only logical that they should explode after the moment music breaks in ioctl vista (line #284, remember ?), before that the diffs are there but seem to me pretty unrelevant to the cdaudio play issue.
After that, they are legion.
CMscdex::StopAudio() seems to be the first to go, not that my log msg there gets weird, it just won't show up, that means that
CDROM_Interface_Ioctl::StopAudio() has failed completely and
return bStat>0;
has returned 0x0.
Then PlayAudioSector() never catches up, then GetAudioStatus() and GetDeviceStatus() in a great cascade.
What do you say, wd (and Qbix and others, of course), was this worth my efforts 😖 ?
Something useful to come up ?
Friends come and go, enemies build up (by an Onymous)
Uhm that's just what the msdn says, up to now a lot seems just deprecated
but fully working, at least according to the information you posted and that
is gathered elsewhere.
For example the TOC function seems to be working just fine afaik.
I did some debugging myself on it and it actually appears to work 100% aside from the small detail that there is no volume coming from the speakers. The play audio IOCTL returns success, the drive is spinning (etc etc)
Just no sound 🙁
