First post, by ripsaw8080
- DOSBox Author
I've looked into the slow performance I posted about earlier regarding Dungeon Keeper Dungeon Keeper speed issue
I had an idea that profiling might show where an unusual amount of processing is going on in DOSBox. After changing the configure file to add the compile flag, I made a clean build of the 0.72 source with profiling enabled.
I used the same path through Dungeon Keeper: run it, start a new game, take first-person control of a creature, let it sit awhile, exit. Basically trying to avoid comparing apples to oranges as much as possible. I did two such runs -- one with no filter on the creature's vision, and one with a filter that results in slow performance. I dumped the profile data to text files with GPROF, and there does seem to be a very prominent difference in one procedure: RENDER_StartLineHandler in render.cpp
I looked at that code, and a super wild guess is that some kind of cache thrash is going on; but I'm not sure what approach to take that might yield useful information. The attached zip file contains the two profile dumps, and I could use some advice on things to investigate.
