First post, by jmk
Wizball should have a bit of PC speaker sampled audio in it, according to this:
http://www.oldskool.org/sound/pc
Here is the routine which might be trying to do it. It is using a PIT mode which has not been added into the emulation - the Hardware Retriggerable One Shot.
0F63:4463 "routine". DI = 09 (usually) SI = Source? CX = Length?
4463 cli
4464 in al,61 or al,2 out 61,al (Speaker data enable).
446A in al,62 or al,20 out 62,al ("timer 2 channel out").
4470 in al,61 and al,FE out 61,al (Speaker data disable).
4476 mov al,92 out 43,al (PIT mode port: counter 2, counter latch, mode 1 (one shot), binary.
447A mov al,FF out 42,al (PIT counter 2, cassette & speaker).
447E mov dl,0
4480 push cx
4481 in al,61 or al,01 out 61,al ("timer 2 gate to speaker enable").
4487 and al,FE out 61,al ("timer 2 gate to speaker disable").
448B mov al,[si] out 42,al -> big table of "sample timing data" (usually 1A-2E).
448F mov cx,di
4491 loop 4491
4493 pop cx
4494 inc si
4495 loop 4480
4497 sti
4498 ret
I'm no expert on the timers and their interaction with the internal speaker... I think it may be trying some sort of pulse-width modulation?
Anyway, if someone who knows better would like to investigate, then I'd be grateful. 😉
