rep movs
First post, by ih8registrations
Has there been any thought of optimizing the decode?
Like:
mov ax, cx
shr cx, 1
rep movsw
mov cx, ax
and cx, 1
rep movsb
or
mov ax, cx
shr cx, 1
rep movsw
and ax,1
jz itseven
movsb
itseven:
etc.
instead of rep movsb.
Reply 1 of 7, by Harekiet
Rank DOSBox Author
DOSBox Author
well the question would be if dos programmers ever used rep movsb when they wanted speed. Would seem they would also use mosw or movsd as much as possible for maximum speed. Your avarage memcpy routine in dos would probably already do a check like that.
Reply 2 of 7, by ih8registrations
Could use qword movs, which they didn't have back then.
mov ax, cx
shr cx, 3
rep movsq
mov cx, ax
and cx, 7
rep movsb
Reply 3 of 7, by ih8registrations
Trying a test implementation. movsb case in decoder.h. What are the input variables to gen_shift_byte_imm?
	/* MOVSB/W/D*/
case 0xa4:
if (decode.rep) {
LOG_MSG("rep str_movsb");
dyn_push(DREG(ECX));
gen_shift_byte_imm(?,?,?,2); // shr cx, 2
// cache_addb(0x51); //PUSH ECX
// gen_preloadreg(DREG(ECX));
// DynRegs[G_ECX].flags|=DYNFLG_CHANGED;
// cache_addw(0xe9c1); // shr ecx, 2
// cache_addb(0x2);
dyn_string(STR_MOVSD); // rep movsd
dyn_pop(DREG(ECX));
// cache_addb(0x59); //POP ECX
gen_dop_word_imm(DOP_AND,false,DREG(ECX),3); // and ecx, 3
dyn_string(STR_MOVSB);
break;
Reply 4 of 7, by wd
Rank DOSBox Author
DOSBox Author
You need gen_shift_word_imm (cx -> _word_imm).
Bitu op,bool dword,DynReg * dr1,Bit8u imm
op is the type of shift/rotate
dword decides if the target reg is word/dword (false here)
dr1 is the register (DREG(ECX) in your case)
imm is the value to rotate (2 here)
As Harekiet already noted it's unlikely that rep movsb code is in time critical
routines and last time i checked it wasn't used a lot in the games that run
slow in dosbox at the moment.
Reply 5 of 7, by ih8registrations
movsw and movsd can be improved with movsq, but since it's not implemented yet, getting the rest worked out by testing on movsb. movsb gets used to mop up odd bytes on later games so if it were to be optimized it'd need a count check added to skip if small.
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
If you wanna use the above code for more than just (speed) tests,
you should definitely get rid of the push/pop pair as that messes up
the stack if the rep movsb triggers a pagefault.
Reply 7 of 7, by ih8registrations
Just an update. The hangup for doing this is there's something in dyn_string that causes dosbox to lock up, perhaps from trying to auto load data for decoding.
