First post, by geronimo1960
hi, I'm using dosbox to run dos serial communication program.
Program works wrong.
The program uses COM1 9600bps, when receives a new message the DOSbox status windows displays
Serial1: Errors occured: Framing 0, Parity 0, Overrun 6 <IF0:2>, Break 0
so I try to set FIFO Enable in 3FA register but the result is the same: overrun error occurs.
Reply if you want, Thanks in advance
