First post, by Og
- Member
Hi, for the last hour I've been trying to find a solution to my problem via the forum search to no avail.
I'm using the CVS from http://www.aep-emu.de/cvscompile/dosbox.htm and everytime I press the alt key DOSBox pauses until I click the mouse or press another key. I tried various options in the config file, I also tried changing the alt key bindings in the mapper, at first, I couldn't even start the keymapper - Ctrl+F1 didn't work, -startmapper (in a batch file) didn't work, the only way I was able to get to the keymapper was Alt+pause>Settings>Keyboard .
I know that CVS builds are not supported, but I was hoping I overlooked something very simple, maybe even stupid...
I'm using WinXP pro, BTW.
[edit]
Forgot to mention that this happens only in window mode
