First post, by Danny252
I recently started playing around with dosbox 0.72 on Vista - I've used .71 before successfully without any problems.
Having installed 0.72, I noticed that the screen seems to forget to refresh after alt-tabbing - but only if the program I've alt-tabbed to doesn't fill the entirety of the dosbox screen.
That probably making no sense, see the picture at the following link:
You can see the text is updating on the right hand side, where the folder behind is, but on the left hand side, it is frozen. Moving dosbox, pressing printscreen, selecting a program with is completely behind dosbox and then alt-tabbing back (i.e. my browser in that picture) all get it updating again.
Seeing as this happens in dosbox itself, no game can be blamed!
PC Specs:
Dell MP061 (Inspiron 9400 Laptop)
Intel Core 2 T7200 2GHz
1024 MB DDR2
ATI Mobility Radeon X1400 380MB Shared
Windows Vista Home
Guessing "Video Mode" is the value under "output" in the config, this is set to "surface"
