SDL_net.h
First post, by Snover
Can't seem to find this header for SDL. Someone please provide it (and dependencies)?
Yes, it’s my fault.
Reply 5 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
the idea is to support modem dailing over tcp/ip
atd ip adress
so you can play multiplayer games over the modem (over tcp/ip)
And/or dail in to BBS which are now usually located on the internet.
Water flows down the stream
Reply 7 of 10, by Aitvo
Is it possible to use the modem device to run a bbs inside dosbox? From glansing at the source it looks like it's possible. How does it work, is it simply a modem on com1 or is it a fossil emulator?
Thx
Reply 8 of 10, by Aitvo
ok.. I figured out how this works, and it's got a ton of potential. Next question, are there any plans to build "virtual modem" aka redirect all dosbox com1 io <> stdio and redirect all dosbox stdio to c:\nul? That would be awesome, in that dosbox could suddenly replace dosemu for bbs doors. 😀
Reply 9 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
I don't get your question.
Dosbox simply has it's own emulated modem. (it's not perfect yet though). You can do with it what you could with any modem.
Reply 10 of 10, by Harekiet
Rank DOSBox Author
DOSBox Author
Rather dosbox has a modem that allows you to dial up to internet addresses with the normal AT commands.
So you can ATDT http://www.myfriendsip.com and if the has his dosbox modem in answering mode you can connect to him, or you can use it to dial up to telnet bbs-es with dos terminal software. Although there's still some bugs in the queues somewhere that causes datastream to get corrupted.
