First post, by jal
I'm currently using the DOSBox debugger (v0.72) under Linux (Ubuntu), and besides some small annoyances (like, F10 and F11 being keys the terminal window uses, which I have to manually disable every time etc.), I found the MEMDUMP function to be not working. MEMDUMPBIN works fine, btw. When I use MEMDUMP, it seems the debugger is not paying attention to the 'len' parameter, instead creating a huuuuuuge file (I killed the process at 150Mb, it was still writing although all kinds of errors appeared on the screen).
I looked at the code, and the bug is that num is declared unsigned, but every iteration 16 is subtracted. So if num is not a multiple of 16, num becomes below zero, but since it is unsigned... I doubt anyone ever used this function, or somebody should've noticed????
Some other annoyance: the file is created uppercase (I don't like that on Linux), and the count is also in hex (why is the number of bytes in hex?).
I could create a patch if I knew how to, but I don't sorry.
JAL
Reply 2 of 4, by jal
wd wrote:
Usually only full segments are dumped 😀
Thanks for reporting this.
You're welcome 😀. I was debugging an old DOS game (I'm trying to create a remake) and had to dump some specific structures to disk, so I used the exact size (which happened to not be a multiple of 16).
JAL
Reply 4 of 4, by jal
wd wrote:
Text dump should be fixed now, maybe you can check if it does what you want.
From what I can see, it works now as it should, I'll test it tonight. Thanks.
EDIT: Ok, it works, as I expected. Got right size and all 😀.
JAL
