First post, by jez
Sniffing around the latest CVS code for DOSbox, it appears that ./configure now automatically includes screenshots support if it detects that libpng is installed, with or without the --enable-shots option. In fact I can't see any code to do with --enable-shots at all.
Suggest you remove all documentation and advice talking about the --enable-shots parameter for ./configure.
== Jez ==
