First post, by beard
Hi, I'm a newbie with a special problem.
I have a problem with an emulator for my first home computer. A SHARP MZ-700.
It works perfect, but.... only below WinNT.
To use it in Windows XP I tried several DOS emulators and VMs.
All with the same effect, that the graphic resolution is not working as in reality.
The graphic card is initialized with:
void InitVGA(void)
union REGS Register;
// set 200 scan lines -> 8x8 font will be activated
Register.w.ax = 0x1200;
Register.w.bx = 0x0030;
int86(0x10, &Register, &Register);
// mode 1, 40 x 25 colour mode
// with MSB set, the screen is not cleared
Register.w.ax = 0x0081;
// activate page 0
Register.w.ax = 0x0500;
// read Cursorsize
Register.h.ah = 0x03;
Register.h.bh = 0x00; // page 0
CursorStartLine = Register.h.ch;
CursorEndLine = Register.h.cl;
And it uses the possibility of an own characterset:
void CGRAMToVGA(void)
* Copy the MZ-CharacterFont (CG-RAM) into the VGA-Card
__dpmi_regs Register;
unsigned char MZMirrorCGRAM[4096];
unsigned short i;
for(i = 0; i < 4096; i++) MZMirrorCGRAM[i] = Mirror(MZCGRAM[i]);
dosmemput(&MZMirrorCGRAM[0], 0x800, __tb);
Register.h.ah = 0x11;
Register.h.al = 0x10;
Register.h.bh = 8; // 8 scan lines
Register.h.bl = 0; // in table 0
Register.x.cx = 256; // 256 characters
Register.x.dx = 0; // first character is ASCII 0
Register.x.es = __tb >> 4;
Register.x.bp = __tb & 0x0F;
__dpmi_int(0x10, &Register);
dosmemput(&MZMirrorCGRAM[0x800], 0x800, __tb);
Register.h.al = 0x00;
Register.h.bl = 1; // in table 1
Register.h.al = 0x03;
Register.h.bl = 0x04;
// Cursor off (have placed here, of course above INT's switches cursor on)
Register.h.ah = 0x01;
Register.x.cx = 0x2100;
It works with DOSBox, (the own charactreset) but the screenresolution is not changed to 320 by 200. I always see garbage on the lower part of the DOSBox screen.
That's 1. ugly and 2. the characters are very small.
The emulator is freeware and you can download it from:
http://www.sharpmz.org/bkkemu.htm
If someone want to test this.
The sourcecode is also downloadable.
I tried all available -machine switches.
It is independent from the PC which I use.
I think it is a general problem of the VGA emulation of DOSBox.
Any ideas?
Best regards,
Beard
Reply 1 of 50, by MiniMax
Rank Moderator
Moderator
DOSBox now emulates several different graphics cards, and 2-3 VGA cards. Please try changing the machine-type in the DOSBox configuration and see if it helps.
_________________
Reply 7 of 50, by beard
@h-a-l-9000
excuse me, but the command ldgfxrom is not available inside the DOSBox.
Please give me a hint.
@QBix
Hm. it is not easy to describe.
For me it looks like that the switching to 40x25 mode works, but the
DOSBox window is not effected by this resolution switch.
I'll write a small test program and post it here soon.
Beard
Reply 9 of 50, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
What if you do the 40x25 modeswitch first and then set 200 lines mode?
ldgfxrom is only availible in debug DOSBox builds and it needs a video BIOS dump file of a corresponding real hardware card.
1+1=10
Reply 10 of 50, by beard
It has nothing todo with the rouitines I showed before.
I'd just written a small test program. For my suprise it was possible to switch
to the 40x25 mode without problems.
So I included the next step.
I installed the own characterset
unsigned short i;
// __dpmi_int(0x10, &Register);
And than it happens inside DOSBox.
Normally the last 2 INT10 calls are included, but for testing, I commented them out.
The link here is removed. See 2 postings below.
It is now attached.
Sourcecode and exe is included
without a parameter it uses the normal characterset,
with a parameter it downloads the MZ characterset.
Beard
Reply 12 of 50, by Qbix
Rank DOSBox Author
DOSBox Author
loadfont changes the scanline register as well as some others. However most of that code has been in dosbox for a long time. (the scanline stuff for 6 years).
Water flows down the stream
Reply 14 of 50, by beard
Hi QBix,
you are right.
I just updated the files and attached them here.
Now it is reduced to the minimum.
It happens when the user font is activated.
I had only one short fast look into the DOSBox sourcecode, so I can not say
anything about it.
It looks that the change of the scanlines has no effect to the DOSBox window.
Again:
without parameter the normal 40 by 25 mode is set.
with a parameter (DOSBoxTest xyz) the own font is activated.
Beard
    DOSBoxTest.zip
    47.09 KiB
    302 downloads
Reply 16 of 50, by ripsaw8080
Rank DOSBox Author
DOSBox Author
This is a known limitation of DOSBox regarding INT 10/AH=12/BL=30. Trying to change to 200 or 350 scanlines in VGA does not work properly, only 400 scanline text modes are supported. This was covered in another thread.
Loading a video BIOS such as the one from Bochs in a debug build of DOSBox works.
Reply 18 of 50, by beard
@wd
On a real PC booted with FreeDOS or in a fullscreen DOS box of Win98 it works correct:
I see 320 by 200 pixels on the fullscreen and not only on half of the screen.
@ripsaw8080
That's strange, because when I make a boot disk image with FreeDOS and
run it with Bochs 2.4.1 I got the same result as with DOSBox.
Also when I use the elpin BIOS.
Beard
Reply 19 of 50, by ripsaw8080
Rank DOSBox Author
DOSBox Author
There aren't many games that use the alternate scanlines, but I know of a couple:
Indenture uses 200 scanlines with a custom font, but I made a workaround for it here.
Wrath of Earth uses 350 scanlines with a custom font in its installer and exit screens, but it's mostly a cosmetic issue, not really important:
Because there are few games that need the feature, I didn't think support would be added internally, so I made a TSR program that acts as an extension to DOSBox's video BIOS in order to support the alternate scanlines. An archive is attached that contains a few text mode utilities that I made, including the TSR.
SCANRES.COM is the resident program that should be loaded prior to running anything that tries to change the scanlines.
CGA.COM, EGA.COM, and VGA.COM are programs that simply switch the DOS text display to 200, 350, and 400 scanlines, respectively; and SCANRES.COM must be loaded for them to work.
CLR.COM is a program to use in place of the CLS command. DOSBox's CLS sets mode 3, so you loose the current mode and any loaded font; but this program uses the scroll window function to clear the screen, as real DOS does, and the current mode and font are preserved.
*X*.COM are a bunch of programs that set a variety of text screen dimensions, including some pretty large ones.
I've only tested the utilities with machine=svga_s3, so anything else might not work. At some point I plan to roll up all these little programs into a single program that takes a command line parameter, but I haven't gotten around to that project yet.
    TEXTUTIL.ZIP
    1.4 KiB
    833 downloads
    Various text mode utilities for DOSBox
