First post, by athemis
Hi!
I've got a problem to compile the cvs version with gcc-3.3.1.
Here's the terminal extract:
make[3]: Entering directory `/var/tmp/portage/dosbox-cvs-20030809/work/dosbox/src/fpu'
source='fpu.cpp' object='fpu.o' libtool=no \
depfile='.deps/fpu.Po' tmpdepfile='.deps/fpu.TPo' \
depmode=gcc3 /bin/sh ../../depcomp \
g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I../../include -march=athlon-tbird -O3 -pipe -g -g -g -c -o fpu.o `test -f fpu.cpp || echo './'`fpu.cpp
rm -f libfpu.a
ar cru libfpu.a fpu.o
ranlib libfpu.a
make[3]: Leaving directory `/var/tmp/portage/dosbox-cvs-20030809/work/dosbox/src/fpu'
Making all in gui
make[3]: Entering directory `/var/tmp/portage/dosbox-cvs-20030809/work/dosbox/src/gui'
source='sdlmain.cpp' object='sdlmain.o' libtool=no \
depfile='.deps/sdlmain.Po' tmpdepfile='.deps/sdlmain.TPo' \
g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I../../include -march=athlon-tbird -O3 -pipe -g -g -g -c -o sdlmain.o `test -f sdlmain.cpp || echo './'`sdlmain.cpp
source='render.cpp' object='render.o' libtool=no \
depfile='.deps/render.Po' tmpdepfile='.deps/render.TPo' \
g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I../../include -march=athlon-tbird -O3 -pipe -g -g -g -c -o render.o `test -f render.cpp || echo './'`render.cpp
source='midi.cpp' object='midi.o' libtool=no \
depfile='.deps/midi.Po' tmpdepfile='.deps/midi.TPo' \
g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I../../include -march=athlon-tbird -O3 -pipe -g -g -g -c -o midi.o `test -f midi.cpp || echo './'`midi.cpp
sdlmain.cpp: In function `void GFX_SetTitle(int, int)':
sdlmain.cpp:86: error: ISO C++ forbids declaration of `internal_cycles' with no
type
sdlmain.cpp:87: error: ISO C++ forbids declaration of `internal_frameskip' with
no type
make[3]: *** [sdlmain.o] Error 1
make[3]: *** Warte auf noch nicht beendete Prozesse...
make[3]: Leaving directory `/var/tmp/portage/dosbox-cvs-20030809/work/dosbox/src/gui'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/var/tmp/portage/dosbox-cvs-20030809/work/dosbox/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/dosbox-cvs-20030809/work/dosbox'
make: *** [all] Error 2
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
Ah I just fixed this error. Please wait till sourceforge updates it's backup server.
(if you want to continue they are Bits)
Water flows down the stream
