First post, by zevv
Hi,
I'm trying to get dosbox running on Yopy, an ARM based linux PDA. First crosscompile went flawlessly, dosbox is running without problems.
Since the Yopy only has a screen of 240x320 pixels, I'd like to hack in a mode to rotate the screen 90 degrees, and scale the image down (just throw away half the pixels, for example)
Can one of the developers give me some quick hints about how hard this would be, where to look in the code ?
Thanks,
Zevv
