First post, by krax
Hi, I wrote a cheat-code system for DOSBox, currently it only works with version 0.74 for win32 and I thought I might as well share it with the forums.
The cheat codes are in a gameshark style, and should be interchangeable with future version of DOSShark.
It includes a scanner so you can make your own cheat-codes.
I attached it in this post, the source code is included and I included some example cheat files for a few games.
Here are some screen-shots:
