More accurate MUNT (MT32 emulation) patch
Reply 40 of 78, by Malignant Manor
Dominus wrote:
the bird chirping is very muted and not the right sound
I found an option to enable more accurate pitch in mt32emu.h which may fix this.
#define MT32EMU_ACCURATENOTES 0
Change to:
#define MT32EMU_ACCURATENOTES 1
It has a note that it could be very slow. I'm not sure about the speed because it doesn't compile.
partial.cpp: In member function 'void MT32Emu::Partial::initKeyFollow(int)':
partial.cpp:145:68: error: invalid types 'MT32Emu::Bit32s [217][float]' for array subscript
partial.cpp: In member function 'void MT32Emu::Partial::startPartial(MT32Emu::dpoly*, const MT32Emu::PatchCache*, MT32Emu::Partial*)':
partial.cpp:171:128: error: cannot call member function 'MT32Emu::File* MT32Emu::Tables::initNote(MT32Emu::Synth*, MT32Emu::NoteLookup*, float, float, float, MT32Emu::PCMWaveEntry*, MT32Emu::File*)' without object
Reply 41 of 78, by ykhwong
Check these and try compiling again.
line 145 of partial.cpp
realVal = synth->tables.tvfKeyfollowMult[((int)noteVal - MIDDLEC) + 108];
line 171 of partial.cpp
synth->tables.initNote(synth, &noteLookupStorage, noteVal, (float)synth->myProp.sampleRate, synth->masterTune, synth->pcmWaves, NULL);
Reply 43 of 78, by ykhwong
Malignant Manor wrote:
That allows it to compile. It cause stuttering for me (some bottleneck probably). Unfortunately, it didn't seem to do anything to help the intro sound.
Yes, that might cause stuttering as it involves more calculations for accuracy. I noticed tiny differences in some games.
Dominus, what if you change "asm volatile" to "__asm__ __volatile__" in a function 'void cpuID()'? Does it compile for MacOS?
Another thing... I need some sample musics of MegaMan X playing in real MT-32. (menu and level 1 music)
Reply 44 of 78, by TeaRex
Here you go. Recorded via DOSBox and a MIDIMATE-II USB-to-MIDI interface from a real first-generation MT-32. The level1 music has a few seconds of the title music in front, but I was too lazy to edit that out.
PS: Moderators, is it OK to post files of this size here? If not, feel free to delete them. In that case, can you, ykhwong, give me a mail address to send them to, or a place to upload them?
    megamanx-title.ogg
    1.12 MiB
    392 downloads
    megamanx-level1.ogg
    1.18 MiB
    436 downloads
tearex
Reply 45 of 78, by HunterZ
TeaRex: Attachment size and type is under Snover's purview, as he is both the forum admin and site host. I assume he has set limits that he is comfortable with, so you should have nothing to worry about.
Reply 46 of 78, by ykhwong
Thanks for the files, TeaRex. 😀 After hearing your oggs, I decided to get rid of a hack that I have added since v2 right now.
    mt32.diff
    213.18 KiB
    351 downloads
Reply 47 of 78, by HunterZ
I tried Mega Man X on MT-32, OPL and GM out of curiosity, and it sounds completely awful to me on all but GM. I'd have expected the OPL music to be awesome since it's a Capcom game, but this is what happens with PC games when they use sound drivers that treat OPL chips like MIDI synths 🙁
Reply 48 of 78, by kode54
You can solve the clipping issue with i386_mixBuffers, i386_mixBuffersRingMix, and i386_produceOutput1, by using paddsw instead of paddw. I don't know what's up with i386_partialProductOutput, though.
Reply 49 of 78, by ykhwong
Awesome, it fixes the issue indeed. 😀
Reply 50 of 78, by Shock
Hey guys and especially ykhwong, I just registered to thank-you for your work on getting MT-32 emulation to work better with DOSBox. It's always given me a headache and I've never been able to get Munt to work. This package seems to make it work.
I have a big program though, I've just tried it with Police Quest II (from the original floppies 🤣!) as that is a game whose soundtrack was designed from the beginning for Roland MT-32 but it sounds terrible on my machine. The lead instruments are all out of pitch and tune and velocity. Is there something wrong with my install or is it just the nature of the current implementation? I'm using the test version 5 from the first page in this thread. I threw the MT-32 roms in the Dosbox folder.
Here is how it sounds on my computer, with many instruments out of tune:
http://members.shaw.ca/snk/pq2mt32emu.mp3
And here is how it sounds on a real Roland MT-32
http://www.youtube.com/watch?v=0dcRmvNYp4s
Any ideas? Thanks!
Reply 51 of 78, by ykhwong
Shock wrote:
Hey guys and especially ykhwong, I just registered to thank-you for your work on getting MT-32 emulation to work better with DOS […]
Any ideas? Thanks!
Don't use it. Try this one.
    test6.7z
    1.34 MiB
    473 downloads
    v6 (binary + patch)
Reply 52 of 78, by Shock
Any ideas? Thanks!
It actually sounds the same with version 6.7, the intruments are still out of tune or sometimes don't even reach the right notes. Listen to the two version. Other games sound decent though so I'm guessing it's just the strange use of chimes and brass modulated through pitch changes in PQ2 that might be causing it to be all out of tune in the emulated version.
Reply 53 of 78, by ykhwong
MT-32 manual claims that standard pitch is 442Hz (0x4a), but I set masterTune to 0x40 here (check attachment) since it sounds a bit better when playing Police Quest II.
    another_test.7z
    1.1 MiB
    497 downloads
Reply 56 of 78, by sergm
Hi!
It is very sad that nobody seems to continue developing of Munt, and even that CVS code never been released since 2009.
Of course, there is gulikoza's build already, but in terms of performance and some sort of "thin" sound, it cannot be compared with 0.1.3 release, even for correctness of pitch.
Surprisingly, Ykhwong and me catch with the same opinion that something should be done... While he returns to wavecached ScummVM code, I was continued struggling...
Last times, I've managed to screw through the code, painfully compile the CVS code with WinMM/DM driver, and even do some work on optimize this stuff.
Finally, I've decided to release at last my work and started "Munt Reloaded" 😀 project on sf.net.
So, everyone is invited to looking at my work here: https://sourceforge.net/projects/muntreloaded/files/
Reply 57 of 78, by sergm
P.S.
In short, v. 0.9.1 released 2011-02-23 features:
* It's Based on latest CVS code from Munt. This means precise pitch and modulation of MIDI playback.
* I've overlooked using the complicated and performance unfriendly Blit algorithm for Wave Generation. Instead, i've used fast band-limited WG, that produces more realistic and bright sound.
* Performance optimizations made (besides WG algo, introduced LUTs and fast float calculations for critical sections). Now it can play MIDIs even on 800 MHz Celeron.
* External Interface code synced with the CVS code. We can again have some fun of looking at that MT-32 Front Panel etc... 😎
* There is win32 app available for use in conjunction with MIDI thru, e.g. MIDI Yoke port. It compiled with correct sample rate (32 KHz) and do not require any installing (not counting installing of MIDI Yoke itself).
Reply 58 of 78, by Reckless
Good to see someone willing/able to work on the driver.
A [very] small point - within the readme there's the following:
In the window that pops up, click "Browse..." and choose the directory to which you unpacked the oemsetup.inf and mt32emu.dll files. Click "OK".
That should obviously refer to mt32emu.inf
Will test out how it sounds later tonight.
Reply 59 of 78, by sergm
Reckless wrote:
Good to see someone willing/able to work on the driver. […]
O, of course, you're right, Reckless. There is no much time to fully update all docs for now... Let's see how interesting this attempt will be... May be it needs to create another thread/topic for this...
