Reply 100 of 110, by Dominus
- DOSBox Moderator
grrr, accidently compiled it with clang and that is known to not work correctly with Dosbox, no matter what arch... Sorry.
With pointing at llvm-gcc
(gcc --version
i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.11.00))
both patches work fine.
Funnily they seem to trigger some kind of overflow in the PCPbench. Sometimes they score around 53fps but often 02.1fps (Gulikozas patch) or 02.2fps (ripsaws patch) (if I set cycles to 12000 I get around 2.3fps (without the leading 0).
32bit built scores over 100fps but is probably so fast it has tearing in the benchmark 😀
So, both patches work, Ripsaws is very slightly faster.
The clang problem is a different issue...
