SVN on OS X - core=dynamic causes segfault
First post, by emendelson
I'm not sure if this is the right place to post this, and I hope it's of some use to someone.
I built the latest SVN on OS X using the technique described by Dominus in another thread. When I run it with a conf file that includes
[cpu]
core=dynamic
the app crashes with a segmentation fault. I've posted the crash report here:
http://dl.dropbox.com/u/271144/SVN-Dynamic-Crash.txt
If this isn't useful to anyone, I hope the admins will let me know, and I'll delete the fie.
Reply 1 of 110, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
If you don't build a 32bit version it will crash. Known issue
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 110, by emendelson
When compiling, I used the environment vars that you specified in an earlier thread:
CFLAGS='-O2 -arch i386' CPPFLAGS='-I/opt/local/include' CXXFLAGS='-O2 -mdynamic-no-pic -arch i386' MACOSX_DEPLOYMENT_TARGET=' […]
MACOSX_DEPLOYMENT_TARGET='10.6'
CXX='/usr/bin/g++-4.2'
F90FLAGS='-O2 -m32'
LDFLAGS='-L/opt/local/lib'
OBJC='/usr/bin/gcc-4.2'
FCFLAGS='-O2 -m32'
INSTALL='/usr/bin/install -c'
OBJCFLAGS='-O2 -arch i386'
FFLAGS='-O2 -m32'
CC='/usr/bin/gcc-4.2'
Doesn't this create a 32-bit build? If not, is there anything else that needs to be done?
I get the segfault crash when launching the build with a .conf file containing only these two lines:
[cpu]
core=dynamic
Anyway, I'll shut up about it after this message!
Reply 3 of 110, by Dominus
DOSBox Moderator
if setting core to dynamic crashes dosbox for you then you made a mistake in compiling, possibly in setting the above flags, thus creating a 64bit version of Dosbox.
things to do:
- check the arch of your compiled dosbox by "lipo -info pathtothedosboxsource/src/dosbox"
- write here EXACTLY what you do and more importantly what you which commands you give in terminal to compile Dosbox. And I mean EXACTLY. Not something like "then I set the environment variables.." but the EXACT command.
I'm pretty sure you are not following some instruction or doing it wrong
Reply 4 of 110, by emendelson
First, you're right: lipo -info reports that the architecture is 'x86_64'.
Here are the steps I follow, written here as I performed them. For this test, by the way, I don't change anything in the makefiles, as I do when trying to compile statically.
(Following your advice, I installed svnX and used it to make a local copy of the latest source in ~/DOSBox\ SVN\ Copy)
1. Open a terminal, cd to ~/DOSBox\ SVN\ Copy/dosbox/trunk.
2. Enter the command: make clean (only if I have built from the same source previously, and I built from this source yesterday).
3. Paste in to the terminal the following commands (which are copied directly from your post in Buidling CVS on OS X 10.6.1, with line breaks added as needed):
F90FLAGS='-O2 -m32'
FCFLAGS='-O2 -m32'
FFLAGS='-O2 -m32'
I leave the same terminal open, enter "set" and check the output. (I've posted the output of set here: http://dl.dropbox.com/u/271144/envvars.txt)
4. Still leaving the same terminal open, I enter:
./autogen.sh
./configure
make
When i ran lipo -info on src/dosbox, it reported:
Non-fat file: dosbox is architecture: x86_64
So obviously I'm doing something wrong. 🙁 But I've studied your posts extremely closely, and I can't see what I'm leaving out.
(I thought a workaround MIGHT be to change the MACOSX_DEPLOYMENT_TARGET= variable to 10.4, but that also produced an x86_64-architectured build.)
Reply 5 of 110, by Dominus
DOSBox Moderator
yep, got it. you are missing an export and added to many linebreaks in step 3....
type "export Cflags=... CXXFlags=...
Reply 6 of 110, by emendelson
That did it! Thank you for catching that.
Just to be certain that what I'm doing is exactly what I should be doing, this is now the batch of commands that I paste into the terminal:
export CFLAGS='-O2 -arch i386' CPPFLAGS='-I/opt/local/include' CXXFLAGS='-O2 -mdynamic-no-pic -arch i386' MACOSX_DEPLOYMENT_TAR […]
F90FLAGS='-O2 -m32'
FCFLAGS='-O2 -m32'
FFLAGS='-O2 -m32'
And, to clarify it completely, this part is a single line:
As you see from your third post in Buidling CVS on OS X 10.6.1, I copied the string correctly, but "export" was missing, and I made the wrong guesses about the line breaks. I'm very grateful to you for helping me get this right.
Reply 7 of 110, by Dominus
DOSBox Moderator
On Linux and OsX you set environment variables through the command export. So, no not yet right, all of those in one line or an export in front of each line...
Reply 8 of 110, by emendelson
So like this...??
export CFLAGS='-O2 -arch i386' export CPPFLAGS='-I/opt/local/include' export CXXFLAGS='-O2 -mdynamic-no-pic -arch i386' ... […]
I think this may not be right, because you said in an earlier message that I added too many line breaks. I'm not clear on which line break (or line breaks) shouldn't be there.
I really hope this is the last time I trouble you for help with this. You've been extremely patient and generous with your time.
Reply 9 of 110, by Dominus
DOSBox Moderator
Either you put it all in one line (like the above example with two of those settings) without ANY linebreak (hence my "too many" linebreaks) or each setting with an export comman up front...
Reply 10 of 110, by emendelson
OK - I've finally got it. Many thanks yet again!
Reply 11 of 110, by ufoufo512
Bumping this thread because I cannot get dynamic core to work on my Snow Leopard. I have followed the instructions given in this and in Make error when installing from svn sources thread.
Before I have been able to make svn builds. Now it crashes as soon as I use dynamic core. Lipo -info reports that dosbox is architecture: i386.
Could somebody, please, check if they are able to make builds with Snow Leopard that don't crash with dynamic core?
Reply 12 of 110, by Dominus
DOSBox Moderator
I'll check tomorrow. If I haven't answered in 24h contact me per PM to remind me 😉
Reply 13 of 110, by emendelson
The build that I put together following the instructions in this thread also crashes with dynamic core. I hadn't tried it until you posted this question.
Reply 14 of 110, by Dominus
DOSBox Moderator
SVN works fine for me. Started Dosbox and then typed
core dynamic
no crash.
Reply 15 of 110, by Qbix
Rank DOSBox Author
DOSBox Author
to be sure enter this as well:
config -h core
check that dynamic is there.
Water flows down the stream
Reply 16 of 110, by Dominus
DOSBox Moderator
config -h core reports back that current value is dynamic
Reply 17 of 110, by emendelson
Same here on the build I made from Dominus's instructions in this thread.
lipo -info reports i386 architecture
config -h core reports dynamic is present
core dynamic causes a crash with the output:
Segmentation fault
logout
Reply 18 of 110, by Dominus
DOSBox Moderator
I can only say that I can't reproduce this at all. Dosbox SVN *just* works here with dynamic core and also when actually stress testing this with PCPbenchmark.... I rest my case.
Reply 19 of 110, by emendelson
The difference is probably the result of the fact that you know what you're doing, while I'm blindly trying to imitate what other people are doing.
Since my application uses only real-mode software, I can easily live with this. Or change the conf to "core=normal".
