Reply 40 of 110, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
step 1. and 2. can be shortcut. We only took the long route because I didn't know you wanted a portable, not fully featured one (and to make sure that this works first before proceeding)
so it would be:
1. Install macports, in terminal run the commands
sudo port install libsdl +universal +no_x11
sudo port install libpng +universal
sudo port install pkgconfig +universal
Step 2. is not necessary anymore (unless you installed libsdl_sound or libsdl_net before)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 42 of 110, by Dominus
DOSBox Moderator
In step 1, remove the sudo install dosbox, otherwise you end up with all the stuff you don't want.
Reply 44 of 110, by gulikoza
Dynrec core crashes because data is above 4GB (something that is not true for Windows and Linux). The first dosbox instruction (if I'm still doing this right 😀) is 0xcd which generates something like:
0x11e84c011:	mov    eax,DWORD PTR [rip-0x1e60f0f7]        # 0x10023cf20 <CPU_Cycles>
0x11e84c017: cmp eax,0x0
0x11e84c01a: jle 0x11e84c06d
0x11e84c020: sub DWORD PTR ds:0x23cf20,0x1
The first 3 instructions are the cycle check I think, the last one is the beginning from dyn_interrupt()->dyn_reduce_cycles()->gen_sub_direct_word()->gen_sub_direct_byte() and it's the one that crashes. Notice how it's trying to substract 1 from CPU_Cycles but the address is obviously wrong.
I don't remember exactly, but we had problems with x86_64 addressing. I do think that at the time the documentation said all data would be <2GB but this is obviously not the case anymore. It appears, x86_64 decoder would need to be rewritten to use RIP relative addressing to make it work on OS X.
http://www.si-gamer.net/gulikoza
Reply 45 of 110, by Dominus
DOSBox Moderator
I'll need to write this all up in the wiki, so we don't need to figure this all out again and again 😉
Thanks guli
Reply 47 of 110, by Dominus
DOSBox Moderator
Are you actually testing this yourself or is there something I should test?
Reply 49 of 110, by wd
Rank DOSBox Author
DOSBox Author
I somewhen tried (shortly) to get it working on win64 but the problem was that
memory addressing would have been awkward as the malloc'd memory for the
generated code was at pretty high adresses whereas regular code was <4GB.
So the currently used 32bit-relative addressing did not work, and only [eax] was
additionally available iirc.
Reply 50 of 110, by gulikoza
This seems to fix it...and hopefully not break anything else 😁
edit: Yeah, I guess the only problem remains when data>4GB and rip offset> +- 2GB. But at least dosbox will not segfault anymore but report the error.
    risc_x64.diff
    4.31 KiB
    218 downloads
Reply 51 of 110, by Dominus
DOSBox Moderator
cool, I try if I have time to try out later... and how it measures speedwise against 32bit dynamic
Reply 52 of 110, by Dominus
DOSBox Moderator
he he, had time right away to test it.
good news: it doesn't crash when I set core dynamic
bad news: it crashes when I start the PCPbench
When I set the core to dynamic before and then start the benchmark I get a sgmentation fault. When I leave it on auto, I get an "illegal instruction" crash.
Reply 54 of 110, by Dominus
DOSBox Moderator
still crashes pcpbench. This time I actually see the starting message of PCPbench before crashing. PCPBench can be downloaded from Benchmark Programs: Some suggestions please?
Reply 56 of 110, by Dominus
DOSBox Moderator
true, but at less than half the speed the 32bit dyncore does 😀
Reply 57 of 110, by wd
Rank DOSBox Author
DOSBox Author
Actually it works if you first run it with normal core and then repeat with dynrec
Maybe some strange caching effect, well...
Of course, it's intended for 64bit only (or non-x86) systems.
Reply 58 of 110, by gulikoza
For me it crashes in FPU_FCOS(), line fpu.regs[TOP].d = cos(fpu.regs[TOP].d);
Seems like something is wrong with math library, code generator correctly constructs the call to FPU_FCOS(), putting a printf at the top of the function works - it crashes at the cos() function.
