First post, by emendelson
I think the answer to this question is "No" but I'll ask in the hope that there might be a different answer.
I'm working on an application for OS X that will launch DOSBox from the command-line and run a DOS application, and will pass to the DOS application some command-line parameters that will be different every time the application is run, like this:
./DOSBox -exit cv.exe infile outfile -option
"infile" will be the name of a filename dropped on the application's icon.
I think this can't be done when launching DOSBox from the command line, and that I will need to do something else (perhaps write a conf file to disk each time the application is run, with an [autoexec.bat] section that includes the filenames).
But if it can be done from the command line, I'll be grateful to learn how to do it.
