First post, by Greyhawk
UPDATE - Another installer based bug found in post #2
If using an actual floppy to install multi-disk game(In my case "Tie Fighter"), it can't find the 2nd disk because the search cache is still reporting the 1st disk. I know no way of quickly checking if the media changed, so the solution would be to empty the cache every FindFirst on "-t floppy" mounted drives. This can be done by:
Add the following to near the top of localDrive::FindFirst in drive_local.cpp:
if ( allocation.mediaid==0xF0 ) { EmptyCache(); } […]
EmptyCache();
This fixes the installer for the disk version of "Tie Fighter", and possibly many other installers for multi-disk games.
I chose FindFirst because it is the same place the CD code check for changed media.
BTW, mediaid really should be enum'd.
Reply 1 of 7, by Greyhawk
Tried installing X-wing, but couldn't get it to see disk 2. Turns out that it was a simple behavior issue with getting the volume name.
When a label isn't found, it should return an error, not "". Adding the following code fixes X-wing installer.
In the file "drive_local.cpp"
In the function "localDrive::FindFirst()"
Immediately after:
if ((sAttr & DOS_ATTR_VOLUME) && (*_dir==0)) {
add:
if ( strcmp(dirCache.GetLabel(), "") == 0 )
dos.errorcode = 0x02;
return false;
I'm guessing on the errorcode, since I couldn't find the exact behavior in my asm book or on the web. (X-wing doesn't care about the errorcode, just the CF)
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
Yeah,
I thought of creating a keycombo that issued a rescan on all drives for that matter.
The cdrom things might be handy ?
Maybe something for finsterr ?
Water flows down the stream
Reply 6 of 7, by HunterZ
dvwjr wrote:
Have your considered "CONTROL-C", just like DOS uses?
??? Wouldn't that be bad if you're installing a game and the installer quits when you hit Ctrl+C?
Reply 7 of 7, by robertmo
I have had a simmilar problem with mounting hdd folder as a floppy. I couldn't delete install.exe from the virtuall floppy after the installation process has begun and after it asked for a new floppy. I have solved it by copying all the floppies to the same folder before the installation.
