First post, by lucky7456969
- Oldbie
Warning 1 warning LNK4075: ignoring '/EDITANDCONTINUE' due to '/INCREMENTAL:NO' specification dosbox.obj dosbox
Warning 2 warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library dosbox dosbox
Warning 3 warning LNK4098: defaultlib 'msvcrt.lib' conflicts with use of other libs; use /NODEFAULTLIB:library MSVCRTD.lib dosbox
Error 4 error LNK2019: unresolved external symbol "public: void __thiscall SaveState::save(unsigned int)" (?save@SaveState@@QAEXI@Z) referenced in function "void __cdecl `anonymous namespace'::SaveGameState(bool)" (?SaveGameState@?A0x4d8293bc@@YAX_N@Z) dosbox.obj dosbox
Error 5 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) ems.obj dosbox
Error 6 error LNK2019: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) referenced in function "unsigned int __cdecl XMS_Handler(void)" (?XMS_Handler@@YAIXZ) xms.obj dosbox
Error 7 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) int10.obj dosbox
Error 8 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) fpu.obj dosbox
Error 9 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) memory.obj dosbox
Error 10 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) timer.obj dosbox
Error 11 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) vga.obj dosbox
Error 12 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) vga_memory.obj dosbox
Error 13 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) dma.obj dosbox
Error 14 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) iohandler.obj dosbox
Error 15 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) joystick.obj dosbox
Error 16 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) keyboard.obj dosbox
Error 17 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) dosbox.obj dosbox
Error 18 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) cpu.obj dosbox
Error 19 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) dos_files.obj dosbox
Error 20 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) cmos.obj dosbox
Error 21 error LNK2019: unresolved external symbol "public: void __thiscall SaveState::load(unsigned int)const " (?load@SaveState@@QBEXI@Z) referenced in function "void __cdecl `anonymous namespace'::LoadGameState(bool)" (?LoadGameState@?A0x4d8293bc@@YAX_N@Z) dosbox.obj dosbox
Error 22 error LNK2019: unresolved external symbol "public: bool __thiscall SaveState::isEmpty(unsigned int)const " (?isEmpty@SaveState@@QBE_NI@Z) referenced in function "void __cdecl `anonymous namespace'::NextSaveSlot(bool)" (?NextSaveSlot@?A0x4d8293bc@@YAX_N@Z) dosbox.obj dosbox
Error 23 error LNK2019: unresolved external symbol "void __cdecl NE2K_Init(class Section *)" (?NE2K_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 24 error LNK2019: unresolved external symbol "void __cdecl GLIDE_Init(class Section *)" (?GLIDE_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 25 error LNK2019: unresolved external symbol "void __cdecl PARALLEL_Init(class Section *)" (?PARALLEL_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 26 error LNK2019: unresolved external symbol "void __cdecl PRINTER_Init(class Section *)" (?PRINTER_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 27 error LNK2019: unresolved external symbol "void __cdecl PS1SOUND_Init(class Section *)" (?PS1SOUND_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 28 error LNK2019: unresolved external symbol "void __cdecl INNOVA_Init(class Section *)" (?INNOVA_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 29 error LNK2019: unresolved external symbol "void __cdecl VOODOO_Init(class Section *)" (?VOODOO_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 30 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) xms.obj dosbox
Error 31 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) int10.obj dosbox
Error 32 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) fpu.obj dosbox
Error 33 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) timer.obj dosbox
Error 34 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) vga.obj dosbox
Error 35 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) vga_memory.obj dosbox
Error 36 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) ems.obj dosbox
Error 37 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) iohandler.obj dosbox
Error 38 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) joystick.obj dosbox
Error 39 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) keyboard.obj dosbox
Error 40 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) memory.obj dosbox
Error 41 error LNK2019: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) referenced in function "public: __thiscall SerializeGlobalPOD::SerializeGlobalPOD(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (??0SerializeGlobalPOD@@QAE@ABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) cpu.obj dosbox
Error 42 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) dos_files.obj dosbox
Error 43 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) cmos.obj dosbox
Error 44 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) dma.obj dosbox
Error 45 error LNK2001: unresolved external symbol "class CParallel * * parallelPortObjects" (?parallelPortObjects@@3PAPAVCParallel@@A) dos.obj dosbox
Error 46 error LNK2001: unresolved external symbol "class CParallel * * parallelPortObjects" (?parallelPortObjects@@3PAPAVCParallel@@A) dos_devices.obj dosbox
Error 47 error LNK2001: unresolved external symbol "class CParallel * * parallelPortObjects" (?parallelPortObjects@@3PAPAVCParallel@@A) bios.obj dosbox
Error 48 error LNK2019: unresolved external symbol "public: __thiscall physfsDrive::physfsDrive(char const *,unsigned short,unsigned char,unsigned short,unsigned short,unsigned char)" (??0physfsDrive@@QAE@PBDGEGGE@Z) referenced in function "public: virtual void __thiscall MOUNT::Run(void)" (?Run@MOUNT@@UAEXXZ) dos_programs.obj dosbox
Error 49 error LNK2019: unresolved external symbol "public: __thiscall physfscdromDrive::physfscdromDrive(char,char const *,unsigned short,unsigned char,unsigned short,unsigned short,unsigned char,int &)" (??0physfscdromDrive@@QAE@DPBDGEGGEAAH@Z) referenced in function "public: virtual void __thiscall MOUNT::Run(void)" (?Run@MOUNT@@UAEXXZ) dos_programs.obj dosbox
Error 50 error LNK2001: unresolved external symbol "char * hdd_size" (?hdd_size@@3PADA) dos_programs.obj dosbox
Error 51 error LNK2019: unresolved external symbol "void __cdecl GetDefaultSize(void)" (?GetDefaultSize@@YAXXZ) referenced in function "public: virtual void __thiscall MOUNT::Run(void)" (?Run@MOUNT@@UAEXXZ) dos_programs.obj dosbox
Error 52 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) dos_programs.obj dosbox
Error 53 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) sdl_gui.obj dosbox
Error 54 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) sdl_mapper.obj dosbox
Error 55 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) sdlmain.obj dosbox
Error 56 error LNK2001: unresolved external symbol "class Voodoo_PageHandler * voodoo_pagehandler" (?voodoo_pagehandler@@3PAVVoodoo_PageHandler@@A) memory.obj dosbox
Error 57 error LNK2001: unresolved external symbol "struct GLIDE_Block glide" (?glide@@3UGLIDE_Block@@A) memory.obj dosbox
Error 58 error LNK2019: unresolved external symbol "struct GLIDE_Block glide" (?glide@@3UGLIDE_Block@@A) referenced in function "void __cdecl DOSBox_SetIcon(void)" (?DOSBox_SetIcon@@YAXXZ) sdlmain.obj dosbox
Error 59 error LNK2019: unresolved external symbol "void __cdecl Voodoo_PCI_Enable(bool)" (?Voodoo_PCI_Enable@@YAX_N@Z) referenced in function "void __cdecl write_pci(unsigned int,unsigned int,unsigned int)" (?write_pci@@YAXIII@Z) pci_bus.obj dosbox
Error 60 error LNK2019: unresolved external symbol "void __cdecl HWOPL_Cleanup(void)" (?HWOPL_Cleanup@@YAXXZ) referenced in function "void __cdecl SBLASTER_ShutDown(class Section *)" (?SBLASTER_ShutDown@@YAXPAVSection@@@Z) sblaster.obj dosbox
Error 61 error LNK2019: unresolved external symbol "void __cdecl HARDOPL_Init(unsigned int,unsigned int,bool)" (?HARDOPL_Init@@YAXII_N@Z) referenced in function "public: __thiscall SBLASTER::SBLASTER(class Section *)" (??0SBLASTER@@QAE@PAVSection@@@Z) sblaster.obj dosbox
Error 62 error LNK2019: unresolved external symbol __imp__fluid_set_log_function referenced in function _fluid_log_config midi.obj dosbox
Error 63 error LNK2019: unresolved external symbol __imp__fluid_default_log_function referenced in function _fluid_log_config midi.obj dosbox
Error 64 error LNK2019: unresolved external symbol __imp__fluid_midi_event_set_sysex referenced in function _fluid_midi_parser_parse midi.obj dosbox
Error 65 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::setDACInputMode(enum MT32Emu::DACInputMode)" (?setDACInputMode@Synth@MT32Emu@@QAEXW4DACInputMode@2@@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 66 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::setReverbOverridden(bool)" (?setReverbOverridden@Synth@MT32Emu@@QAEX_N@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 67 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::writeSysex(unsigned char,unsigned char const *,unsigned int)" (?writeSysex@Synth@MT32Emu@@QAEXEPBEI@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 68 error LNK2019: unresolved external symbol "public: bool __thiscall MT32Emu::Synth::open(struct MT32Emu::SynthProperties &)" (?open@Synth@MT32Emu@@QAE_NAAUSynthProperties@2@@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 69 error LNK2019: unresolved external symbol "public: __thiscall MT32Emu::Synth::Synth(void)" (??0Synth@MT32Emu@@QAE@XZ) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 70 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::render(short *,unsigned int)" (?render@Synth@MT32Emu@@QAEXPAFI@Z) referenced in function "void __cdecl MT32_CallBack(unsigned int)" (?MT32_CallBack@@YAXI@Z) midi.obj dosbox
Error 71 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::close(void)" (?close@Synth@MT32Emu@@QAEXXZ) referenced in function "public: virtual void __thiscall MidiHandler_mt32::Close(void)" (?Close@MidiHandler_mt32@@UAEXXZ) midi.obj dosbox
Error 72 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::playMsg(unsigned int)" (?playMsg@Synth@MT32Emu@@QAEXI@Z) referenced in function "public: virtual void __thiscall MidiHandler_mt32::PlayMsg(unsigned char *)" (?PlayMsg@MidiHandler_mt32@@UAEXPAE@Z) midi.obj dosbox
Error 73 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::playSysexWithoutFraming(unsigned char const *,unsigned int)" (?playSysexWithoutFraming@Synth@MT32Emu@@QAEXPBEI@Z) referenced in function "public: virtual void __thiscall MidiHandler_mt32::PlaySysex(unsigned char *,unsigned int)" (?PlaySysex@MidiHandler_mt32@@UAEXPAEI@Z) midi.obj dosbox
Error 74 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::playSysex(unsigned char const *,unsigned int)" (?playSysex@Synth@MT32Emu@@QAEXPBEI@Z) referenced in function "public: virtual void __thiscall MidiHandler_mt32::PlaySysex(unsigned char *,unsigned int)" (?PlaySysex@MidiHandler_mt32@@UAEXPAEI@Z) midi.obj dosbox
Error 75 error LNK2019: unresolved external symbol "public: __thiscall MT32Emu::Synth::~Synth(void)" (??1Synth@MT32Emu@@QAE@XZ) referenced in function "public: void * __thiscall MT32Emu::Synth::`scalar deleting destructor'(unsigned int)" (??_GSynth@MT32Emu@@QAEPAXI@Z) midi.obj dosbox
Error 76 error LNK2019: unresolved external symbol __imp__new_fluid_midi_router referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 77 error LNK2019: unresolved external symbol __imp__fluid_synth_handle_midi_event referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 78 error LNK2019: unresolved external symbol __imp__delete_fluid_synth referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 79 error LNK2019: unresolved external symbol __imp__fluid_synth_sfload referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 80 error LNK2019: unresolved external symbol __imp__delete_fluid_settings referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 81 error LNK2019: unresolved external symbol __imp__new_fluid_synth referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 82 error LNK2019: unresolved external symbol __imp__fluid_settings_setnum referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 83 error LNK2019: unresolved external symbol __imp__fluid_settings_setstr referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 84 error LNK2019: unresolved external symbol __imp__new_fluid_settings referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 85 error LNK2019: unresolved external symbol __imp__fluid_synth_write_s16 referenced in function "void __cdecl synth_CallBack(unsigned int)" (?synth_CallBack@@YAXI@Z) midi.obj dosbox
Error 86 error LNK2019: unresolved external symbol __imp__delete_fluid_midi_router referenced in function "public: virtual void __thiscall MidiHandler_synth::Close(void)" (?Close@MidiHandler_synth@@UAEXXZ) midi.obj dosbox
Error 87 error LNK2019: unresolved external symbol __imp__fluid_midi_router_handle_midi_event referenced in function "public: virtual void __thiscall MidiHandler_synth::PlayMsg(unsigned char *)" (?PlayMsg@MidiHandler_synth@@UAEXPAE@Z) midi.obj dosbox
Error 88 error LNK2019: unresolved external symbol "struct HWND__ * __cdecl GetHWND(void)" (?GetHWND@@YAPAUHWND__@@XZ) referenced in function "void __cdecl UI_Shortcut(int)" (?UI_Shortcut@@YAXH@Z) sdl_gui.obj dosbox
Error 89 error LNK2001: unresolved external symbol "struct HWND__ * __cdecl GetHWND(void)" (?GetHWND@@YAPAUHWND__@@XZ) sdl_mapper.obj dosbox
Error 90 error LNK2001: unresolved external symbol "struct HWND__ * __cdecl GetHWND(void)" (?GetHWND@@YAPAUHWND__@@XZ) sdlmain.obj dosbox
Error 91 error LNK2019: unresolved external symbol "void __cdecl DOSBox_RefreshMenu(void)" (?DOSBox_RefreshMenu@@YAXXZ) referenced in function "void __cdecl MAPPER_RunInternal(void)" (?MAPPER_RunInternal@@YAXXZ) sdl_mapper.obj dosbox
Error 92 error LNK2001: unresolved external symbol "void __cdecl DOSBox_RefreshMenu(void)" (?DOSBox_RefreshMenu@@YAXXZ) sdlmain.obj dosbox
Error 93 error LNK2019: unresolved external symbol "void __cdecl GLIDE_ResetScreen(bool)" (?GLIDE_ResetScreen@@YAX_N@Z) referenced in function "void __cdecl GFX_ResetScreen(void)" (?GFX_ResetScreen@@YAXXZ) sdlmain.obj dosbox
Error 94 error LNK2019: unresolved external symbol "public: long __thiscall CDirect3D::Resize3DEnvironment(unsigned int,unsigned int,unsigned int,unsigned int,bool)" (?Resize3DEnvironment@CDirect3D@@QAEJIIII_N@Z) referenced in function "unsigned int __cdecl GFX_SetSize(unsigned int,unsigned int,unsigned int,double,double,void (__cdecl*)(enum GFX_CallBackFunctions_t))" (?GFX_SetSize@@YAIIIINNP6AXW4GFX_CallBackFunctions_t@@@Z@Z) sdlmain.obj dosbox
Error 95 error LNK2019: unresolved external symbol "public: long __thiscall CDirect3D::LoadPixelShader(char const *,double,double)" (?LoadPixelShader@CDirect3D@@QAEJPBDNN@Z) referenced in function "unsigned int __cdecl GFX_SetSize(unsigned int,unsigned int,unsigned int,double,double,void (__cdecl*)(enum GFX_CallBackFunctions_t))" (?GFX_SetSize@@YAIIIINNP6AXW4GFX_CallBackFunctions_t@@@Z@Z) sdlmain.obj dosbox
Error 96 error LNK2019: unresolved external symbol "void __cdecl DOSBox_CheckOS(int &,int &,int &)" (?DOSBox_CheckOS@@YAXAAH00@Z) referenced in function "void __cdecl SDLScreen_Reset(void)" (?SDLScreen_Reset@@YAXXZ) sdlmain.obj dosbox
Error 97 error LNK2019: unresolved external symbol "void __cdecl SetVal(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?SetVal@@YAXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V12@0@Z) referenced in function "void __cdecl change_output(int)" (?change_output@@YAXH@Z) sdlmain.obj dosbox
Error 98 error LNK2019: unresolved external symbol "public: long __thiscall CDirect3D::InitializeDX(struct HWND__ *,bool)" (?InitializeDX@CDirect3D@@QAEJPAUHWND__@@_N@Z) referenced in function "void __cdecl d3d_init(void)" (?d3d_init@@YAXXZ) sdlmain.obj dosbox
Error 99 error LNK2019: unresolved external symbol "private: void __thiscall CDirect3D::DestroyD3D(void)" (?DestroyD3D@CDirect3D@@AAEXXZ) referenced in function "public: __thiscall CDirect3D::~CDirect3D(void)" (??1CDirect3D@@QAE@XZ) sdlmain.obj dosbox
Error 100 error LNK2019: unresolved external symbol "void __cdecl DOSBox_NoMenu(void)" (?DOSBox_NoMenu@@YAXXZ) referenced in function "void __cdecl openglhq_init(void)" (?openglhq_init@@YAXXZ) sdlmain.obj dosbox
Error 101 error LNK2019: unresolved external symbol "public: bool __thiscall CDirect3D::LockTexture(unsigned char * &,unsigned int &)" (?LockTexture@CDirect3D@@QAE_NAAPAEAAI@Z) referenced in function "bool __cdecl GFX_StartUpdate(unsigned char * &,unsigned int &)" (?GFX_StartUpdate@@YA_NAAPAEAAI@Z) sdlmain.obj dosbox
Error 102 error LNK2019: unresolved external symbol "public: bool __thiscall CDirect3D::UnlockTexture(unsigned short const *)" (?UnlockTexture@CDirect3D@@QAE_NPBG@Z) referenced in function "void __cdecl GFX_EndUpdate(unsigned short const *)" (?GFX_EndUpdate@@YAXPBG@Z) sdlmain.obj dosbox
Error 103 error LNK2019: unresolved external symbol "void __cdecl MountDrive_2(char,char const * const,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?MountDrive_2@@YAXDQBDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl OpenFileDialog(char *)" (?OpenFileDialog@@YAXPAD@Z) sdlmain.obj dosbox
Error 104 error LNK2019: unresolved external symbol "bool __cdecl DOSBox_Kor(void)" (?DOSBox_Kor@@YA_NXZ) referenced in function "void __cdecl OpenFileDialog(char *)" (?OpenFileDialog@@YAXPAD@Z) sdlmain.obj dosbox
Error 105 error LNK2019: unresolved external symbol "void __cdecl Mount_Zip(char,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?Mount_Zip@@YAXDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl OpenFileDialog_Img(char)" (?OpenFileDialog_Img@@YAXD@Z) sdlmain.obj dosbox
Error 106 error LNK2019: unresolved external symbol "void __cdecl Mount_Img(char,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?Mount_Img@@YAXDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl OpenFileDialog_Img(char)" (?OpenFileDialog_Img@@YAXD@Z) sdlmain.obj dosbox
Error 107 error LNK2019: unresolved external symbol "void __cdecl mem_conf(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,int)" (?mem_conf@@YAXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 108 error LNK2019: unresolved external symbol "void __cdecl BrowseFolder(char,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?BrowseFolder@@YAXDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 109 error LNK2019: unresolved external symbol "void __cdecl MountDrive(char,char const * const)" (?MountDrive@@YAXDQBD@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 110 error LNK2019: unresolved external symbol "void __cdecl UnMount(int)" (?UnMount@@YAXH@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 111 error LNK2019: unresolved external symbol "void __cdecl ToggleMenu(bool)" (?ToggleMenu@@YAX_N@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 112 error LNK2019: unresolved external symbol _closedir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 113 error LNK2019: unresolved external symbol _readdir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 114 error LNK2019: unresolved external symbol _opendir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 115 error LNK2001: unresolved external symbol "unsigned int hdd_defsize" (?hdd_defsize@@3IA) sdlmain.obj dosbox
Error 116 error LNK2019: unresolved external symbol "void __cdecl DOSBox_SetMenu(void)" (?DOSBox_SetMenu@@YAXXZ) referenced in function _SDL_main sdlmain.obj dosbox
Error 117 error LNK2019: unresolved external symbol "public: void __thiscall CParallel::initialize(void)" (?initialize@CParallel@@QAEXXZ) referenced in function "unsigned int __cdecl INT17_Handler(void)" (?INT17_Handler@@YAIXZ) bios.obj dosbox
Error 118 error LNK2019: unresolved external symbol "public: unsigned char __thiscall CParallel::getPrinterStatus(void)" (?getPrinterStatus@CParallel@@QAEEXZ) referenced in function "unsigned int __cdecl INT17_Handler(void)" (?INT17_Handler@@YAIXZ) bios.obj dosbox
Error 119 fatal error LNK1120: 77 unresolved externals .\Debug/dosbox.exe dosbox
Any ideas how to solve 'em
Thanks
Jack
