Reply 20 of 23, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
use mingw/msys 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 22 of 23, by lucky7456969
ykhwong wrote:
mp3cue patch is already applied to the source. So you have to get rid of it in order to remove SDL_sound dependency. This is dif […]
mp3cue patch is already applied to the source. So you have to get rid of it in order to remove SDL_sound dependency. This is diff that you can revert the patch.
patch binary is here.
http://gnuwin32.sourceforge.net/packages/patch.htm
In your source directory type
patch -up1 < revert.diff
Sorry for resurrecting this thread. I have downloaded patch.exe.
Where should I start patching. in the src folder or the "root" folder
or the dos subfolder? the letter '1' hangs my command prompt.
Reply 23 of 23, by Dominus
DOSBox Moderator
in the src folder may still need to specify -p or -up depending on the patch
